92 accord oil leak... HELP!
Old Mar 9, 2005 | 11:30 AM
jcpegg's Avatar
Default 92 accord oil leak... HELP!
I'm leaking oil pretty badly and can't figure out where it's coming from. It LOOKS like it is coming from above the oil filter somewhere. I have replaced the valve cover gasket, the oil filter, the oil pressure sending unit, and cut into the oil cooling hose thinking that the leak was coming from there. What else could be leaking above the oil filter? The oil seems to either come from the block where the filter meets or from above that point, it drips down onto the base of the oil filter and makes its way around the filter until it drips directly onto the exhaust. Causes lots of smoke! I can also hear an airy sound that I've never noticed before while the motor is running. It sounds like a slow air leak from a tire. Help!
Old Mar 9, 2005 | 08:38 PM
BaddMo2002's Avatar
have you checked the balance shaft seal? I know those things go bad on the 94-97's.
swappedefloveit
Aug 12, 2013 03:06 PM
chiaxi2002
Apr 9, 2010 08:56 PM
italstallion
Sep 5, 2007 12:08 PM
92ehatch
Feb 21, 2006 07:02 PM
Hippie
Oct 1, 2002 08:33 AM
