cable trans input shaft?
Old Mar 9, 2005 | 11:24 AM
HPDE007's Avatar
Default cable trans input shaft?
I was wondering if any of you know how to tell the difference between a hydro trans input shaft and a cable one? I have a box of b series tranny parts from misc trannys and want to know which input shaft I have. Any pics or descriptions would be helpful.
Thanks
Old Mar 9, 2005 | 12:42 PM
3.504's Avatar
Default Re: cable trans input shaft? (HPDE007)
here's what i found.
cable clutch mainshaft (input) = #20
hydro clutch mainshaft = #3
if you notice the cable has the extra splines on the backside of the shaft, also the counter's for each spline up completly differently, they might still swap, line them up side by side if you have both and see whats all different, take some pics if you can cause i'd like to know. here are the specs, they're all the same:
cable clutch
hydro clutch
cable clutch is a 92 integra LS and the hydro clutch is 95 integra GSR
you'll also have to remember the mainshaft on 91 and previous year tranny is small splined for the clutch disc.
off topic: does your username mean honda performance development engineer???!!!!
Modified by 3.504 at 5:16 PM 3/9/2005
Old Mar 9, 2005 | 03:00 PM
HPDE007's Avatar
Default Re: cable trans input shaft? (3.504)
My user name HPDE stands for High performance driving event. I am into driving events and racing. If you are a DA guy check out this post on another board with pics of my racecar build in progress. http://www.g2ic.com/forums/showthread.php?t=112395
I am H4DA on that board. Thanks for the info.
turbo-crx
Oct 7, 2008 02:45 PM
egb16pg
Jan 21, 2007 10:38 AM
Flamegurl
Jul 24, 2005 12:44 PM
Dosvita
Mar 20, 2005 03:01 PM
ldanphanl
Mar 6, 2005 08:50 PM
