C&R racing radiator with air conditioning?
Old Mar 9, 2005 | 11:16 AM
Project X's Avatar
Default C&R racing radiator with air conditioning?
Anyone know if it's possible to install a C&R racing radiator on a A/C-equipped Teg or does the A/C need to be removed?
Old Mar 9, 2005 | 11:27 AM
Haleiwa-Brando's Avatar
Default Re: C&R racing radiator with air conditioning? (Project X)
You can do this. It's easier than you think Here is what you do:
You will obviously be taking off the stock radiator, radiator fan and A/C condensor fan.
You will then install the aftermarket radiator and your aftermarket radiator fan that goes with it. You will have to get another aftermarket fan but your going to need a 'pusher' type. Install this on the front of your A/C radiator...and your good to go.
Old Mar 9, 2005 | 11:30 AM
.doeboyfresh.'s Avatar
From: Boswanna,street radio,riddin in da regal. PA.LLday
Default Re: C&R racing radiator with air conditioning? (Haleiwa-Brando)
just put the windows down ac is overrated
Old Mar 9, 2005 | 11:36 AM
Project X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">You can do this. It's easier than you think Here is what you do:
You will then install the aftermarket radiator and your aftermarket radiator fan that goes with it. You will have to get another aftermarket fan but your going to need a 'pusher' type. Install this on the front of your A/C radiator...and your good to go.</TD></TR></TABLE>
Is the pusher-type fan needed or can I do with just the C&R rad fan?
Old Mar 9, 2005 | 11:45 AM
Default Re: C&R racing radiator with air conditioning? (TeGmAn18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeGmAn18 &raquo;</TD></TR><TR><TD CLASS="quote">just put the windows down ac is overrated </TD></TR></TABLE>
Personally I agree. I even live in Hawaii = 90 deg every day. I've always removed the AC.
To answer your question PROJECT X, it would be best if you installed a seperate fan.
210southstar
Aug 25, 2010 05:28 AM
eightvalver
Sep 22, 2007 01:17 PM
cpforyou
Jul 3, 2005 10:16 AM
4piston
Jan 27, 2005 07:11 PM
