what kinda cat is everyone running wit jdm 4-1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toukna »</TD></TR><TR><TD CLASS="quote">how is the jdm dc??? I keep on hearing that its crap... but its the best bang for the buck... what do you think of it?</TD></TR></TABLE>
I have the jdm dc 4-1 2.5 .....its fine to me...its bit tab lower at the bottom but other then that its fine.....dont know how low the jdm type R header though...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITSUBA »</TD></TR><TR><TD CLASS="quote">A HOLLOWED OUT STOCK CAT.</TD></TR></TABLE>
WONT FIT
Carsound cats are a good deal
WONT FIT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00sted4dr »</TD></TR><TR><TD CLASS="quote">
WONT FIT
Carsound cats are a good deal</TD></TR></TABLE>
What makes you think it won't fit? Have you tried? or are you just guessing? Because I know of three cars that say it will fit. It does take a bit of modificatin of the stock CAT but it does work.
And yeah I'd say go with a Carsound CAT as well, if you are looking to go high flow.
WONT FIT
I'm running the OEM cat. I used to have a 2.5" carsound cat, but with the strict cali emissions, I had get rid of it. A muffler shop cut off the latter half of the carsound cat (so the 2.5" donut gasket was still connected to the carsound cat), and welded on the OEM unit. I'll get pics if you want.
I am running a 17.5" Magnacore Racing Cat with my JDM 4-1 on my LS. Stck LS cat is too long. hooked up to APEXI WS exhaust..
Hope that helps..
Hope that helps..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kapman38 »</TD></TR><TR><TD CLASS="quote">I am running a 17.5" Magnacore Racing Cat with my JDM 4-1 on my LS. Stck LS cat is too long. hooked up to APEXI WS exhaust..
Hope that helps..</TD></TR></TABLE>isn't the stock cat 17.5'?
I had a catsound stock LS cat, but the JDM header is longer then 4-2-1 stock USDM header. So you need a shorter cat to keep same total length of exhaust. Or it will rub against fuel tank (Not good) I maybe incorrect in length, but will got back and measure.
I got a spun bodied high flow cat from SMSP. He did a flowbench test and it ended up flowing better than the carsound and some other brand he tested.
