Will 2000 si springs fit 93 ex coupe?
Yes, the spring perches are the same. Rates and lengths and car weights may vary a bit so don't expect the exact same ride heights but it should be a similar ballpark.
Closely measure the height before and after. If the height changes then you will want to recheck the toe and the camber to a lesser degree. Bouncy will be a comparison of spring rates and generally I would make a guess that the Si rate might be a little higher than the older EX but probably not by much.
ic3pham
Sep 13, 2008 11:15 AM
garrettej8
Sep 2, 2005 08:00 AM
classciv
Feb 21, 2005 08:57 PM
