Advice on N/A & Nos
Old Mar 9, 2005 | 09:56 AM
reynosop's Avatar
Default Advice on N/A & Nos
I have a demila that has killed me inside, I was currently planning on bosting a set up like this. After talking to some PRO in this forum i came with the conclusion that it was not safe for me to do this at all ! So i decided to stay all motor with this set, i know i have to change my injectors to smaller one.
My question here, Has any one here ever ran a 95mm crank or has sprayed on NA motors ? which type of cams should i be getting with this set up? i want to produce as much power as i can with this set up
B18A: (95mm crank, H beam rods, 10.1 comp flat head 84mm bore, rs sleeves)
B18C1Port and polish, Skunk2&P manifold,retainers,springs,sprokets,CTR, 1mm valves)
Jdm ITR(AEM,Fuel pump, rail, regulator) MSD: cap,col blaster, msd6digital, hondata s200. t3/t4 turbo .57 trim 63 a/r
few more things here, which nos set up will suit me best? and how far can i rev this crank up to?
Modified by reynosop at 11:47 PM 3/9/2005
Old Mar 9, 2005 | 09:59 AM
reynosop's Avatar
Default Re: Advice on N/A & Nos (reynosop)
Old Mar 9, 2005 | 12:16 PM
reynosop's Avatar
any one ??????????????????????????
Old Mar 9, 2005 | 02:18 PM
HobbesGSR's Avatar
I'm a bit confused about your setup.. could you break it down part by part... and you have an FMU and a hondata? - If you clarify I may be able to answer a few questions.
Old Mar 9, 2005 | 02:35 PM
reynosop's Avatar
Default Re: Advice on N/A & Nos (HobbesGSR)
no FMU,,, just hondata s200
jdmscene87
Sep 12, 2012 09:40 AM
rdssk8rcs1
Jun 22, 2009 06:39 PM
eglslsd
Jun 29, 2007 10:30 AM
BigBodySmith
Apr 21, 2006 03:05 PM
redturbohatch
Feb 2, 2004 10:07 PM
