1994 RS Overheating
Old Mar 9, 2005 | 08:10 AM
2kTeg's Avatar
Default 1994 RS Overheating
Ok i know overheating has been coverd but nothing is the same as my scenario...
The car will only over heat when im driving up hill for a long time or with a lot of weight in the car, if i am in 5th gear with the heater on the temp continues to go up, if i drop it in 4th and get in it then it will cool down. I drive this car everyday to school like 20miles and its all flat stop and go traffic and its fine. Also the heater kinda sucks like it wont heat up unless im driving for awhile. any help would be great.
1994 Integra RS
175,000 miles all female driven except the last 10,000
Old Mar 9, 2005 | 11:12 AM
2kTeg's Avatar
Default Re: 1994 RS Overheating (2kTeg)
bump for ideas
Old Mar 9, 2005 | 01:28 PM
JimBlake's Avatar
You could try a new thermostat first, but it kinda sounds like your radiator is clogged up & can't handle the extra heat from climbing or heavy loads. Maybe you can clean it out with some of that superflush or whatever stuff.
When it gets hot does the radiator fan start up?
Old Mar 9, 2005 | 02:37 PM
2kTeg's Avatar
the fans are fine the start and run, im going to do the therm and flush it all thanks for the help bro
Old Mar 12, 2005 | 07:11 PM
RS DC4 94's Avatar
i had the exact same problem in my 94 rs. my problem was the water pump.
Old Mar 12, 2005 | 07:23 PM
BlownVR's Avatar
Default Re: 1994 RS Overheating (JimBlake)
check thermostat and then radiator hoses, check for leaks, check coolant, check fan to make sure its activating. if it dosen't fix the problem then you have a blown headgasket.
Old Mar 30, 2005 | 01:48 PM
2kTeg's Avatar
Default Re: 1994 RS Overheating (NismoSpec)
the fans works there is no leaks the car only overheats after a long period of getting on it... there is no smoke, if the head gasket was blown wouldn't there be smoke?
str8shooter
Feb 8, 2009 09:34 AM
jlude90
Jul 13, 2008 04:46 PM
EjSex
12
May 17, 2007 10:23 AM
FOrSfEd
Feb 5, 2004 04:48 PM
1CiViC1
13
May 29, 2003 05:41 AM
