Suspension & Brakes Theory, alignment, spring rates....
should i stick with ITR springs?
Old Mar 8, 2005 | 10:54 PM
Wazup's Avatar
Default should i stick with ITR springs?
i currently have JDM ITR springs on my car and was thinking about switching to either tein H-tech springs or goldlines. i only daily drive, so i dont need anything really stiff or too low. i know the goldlines have a 1.25 inch drop and the H-techs are 1.3F/1.1R. so they dont sound too bad..
any opinions? im asking also because i wonder if the ITR springs are stiffer than either of those
Old Mar 9, 2005 | 05:37 AM
RagingAngel's Avatar
Default Re: should i stick with ITR springs? (Wazup)
what year JDM ITR springs do you have?
I used to have all this committed to memory, but without specific numbers I do know that the 98spec rates are 0.1kg/mm heavier than the 96spec.
The 96spec springs are 4.4kg/mm front while the rears are progressive 2.2~4.4kg/mm
Add accordingly with 98spec.
Old Mar 9, 2005 | 08:24 AM
Targa250R's Avatar
be professional
Just keep your ITR springs.
Old Mar 9, 2005 | 11:39 AM
Wazup's Avatar
Default Re: should i stick with ITR springs? (Targa250R)
waste of money i guess?
TeGGY_LS
Mar 30, 2004 11:19 AM
yoda888
Nov 3, 2003 09:43 AM
HapiHonda
Oct 27, 2002 03:52 PM
