How to identify a Toda oil pump gear?
Old Mar 8, 2005 | 09:45 PM
NiceDc2r's Avatar
Default How can you tell a difference between toda oil pump gear abd the oem type r oil pump gear???
How can you tell a difference between toda oil pump gear and the oem type r oil pump gear??? I just got one, or at least i think i did... it was used and came in thee toda box and packaging but it was really cheap... are there any identifying Marks on th toda or the oem gear???
Old Mar 9, 2005 | 08:22 PM
NiceDc2r's Avatar
Default Re: How can you tell a difference between toda oil pump gear abd the oem type r oil pump gear??? (Ni
ttt
Old Mar 9, 2005 | 08:26 PM
BlueR's Avatar
http://www.todaracing.com/prod....html
doesn't look like it has any identifying marks
Old Mar 10, 2005 | 07:36 AM
NiceDc2r's Avatar
To determine which size fits your engine, you must remove your original oil pump gear and measure it. If your engine is equipped with a 80mm oil pump gear, then only the TODA 80mm oil pump gear will fit. Some B-series engines (B16A,B16B,B18C) have 80mm oil pump gears and some have 84mm oil pump gears.
Where are these measuremants taken from???
raverx3m
Jun 16, 2016 06:58 PM
db1love
Dec 8, 2010 11:27 AM
Turbo O
Jun 8, 2006 02:19 PM
bitr364
Aug 20, 2003 07:27 PM
Mike K
Jul 31, 2001 02:42 PM
