help speedometer not working
Old Mar 8, 2005 | 08:23 PM
7speed's Avatar
Default help speedometer not working
ever since i got my swap to the h22 my speedometer has worked, meaning i cant till how fast im going, and also cuz i got the check engine light,i guess this y my vtec doesn't pop, ,,,but anyway they check all the signal and everthing is getting read, but i still cant know how fast im going, could it be possible when they swap my motor they could have disconted something behind my dashboard?????
and yes i wired the vtec,,,,,
p.s
im using the gsr ecu on my h22, i get a very bad cold start, it turns off 3 times before it warms up, the guy told me that i need a fuel pump regulater is that true?,,,,,,,
p.s.s
yes im the same guy that say that im not impress with the h22, in my 97 accord 2dr coupe
Old Mar 9, 2005 | 09:56 AM
BaddMo2002's Avatar
what is your check engine light for?
Old Mar 9, 2005 | 10:41 AM
raceACCORDingly's Avatar
have you checked the VSS?
i think swapping to a p13 ecu will clear up some of your problems also.
Old Mar 9, 2005 | 12:42 PM
90accorddx's Avatar
Default Re: help speedometer not working (7speed)
Definately check the VSS (Vehicle speed sensor)
H22*CiViC
Jun 8, 2010 12:54 PM
EP1C
Dec 27, 2009 01:46 PM
RooSter
Nov 22, 2007 04:31 PM
