GSR seats fit into a 00 Civic Coupe?
Old Mar 8, 2005 | 07:40 PM
saigon1965's Avatar
Default GSR seats fit into a 00 Civic Coupe?
How easy is it to fit a pair of 00 GSR seats into an 00 Civic Coupe? am sure that the rails are not the same, will there be any relocation involve? Thanks.
Old Mar 8, 2005 | 08:38 PM
RVCA97's Avatar
Default Re: GSR seats fit into a 00 Civic Coupe? (saigon1965)
i have some GSR seat on my 98 hatch and it bolts up perfectly except one bolt, still sits pretty tight so there is no real problem with direct bolt on.... btw i believe all 96-00 civc seats are the same so hope this helps you out
Old Mar 8, 2005 | 09:23 PM
Evo-man@20psi's Avatar
Yeah I have a fresh set of black leathers from a gsr in my 2000 si they should bolt right up
Old Mar 17, 2006 | 08:58 AM
ityab0y's Avatar
Default Re: GSR seats fit into a 00 Civic Coupe? (Evo-man@20psi)
i have gsr cloth, and there is no way the bolts line up. people assure me they fit but they don't, unless you cut up the rail or something. back right of driver and back left of pass seat arn't even close.
anyone shed some light on me
Old Mar 17, 2006 | 09:06 AM
ezekiel1059's Avatar
Default Re: GSR seats fit into a 00 Civic Coupe? (d0nfry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RVCA97 &raquo;</TD></TR><TR><TD CLASS="quote">i have some GSR seat on my 98 hatch and it bolts up perfectly except one bolt, still sits pretty tight so there is no real problem with direct bolt on.... btw i believe all 96-00 civc seats are the same so hope this helps you out </TD></TR></TABLE>
notice how he said except one bolt... not sure about the rails but to put del sols in my coupe, i had to switch out the rails.
Old Mar 17, 2006 | 09:11 AM
Jonas99's Avatar
Default Re: GSR seats fit into a 00 Civic Coupe? (ezekiel1059)
swap out the inner rails with your stock rails. this way you retain the civic seat belt clip and your bolt holes line up the right way. you can leave the outside rail in tact - it will bolt right up. seats sit slightly lower than your stock civic seats.
bullitz400
Nov 24, 2008 06:00 AM
Pnoyej6
Nov 14, 2005 02:42 PM
LvN
24
Apr 19, 2005 06:33 PM
newBcrxer
Mar 2, 2004 09:57 AM
civiccivic
11
Sep 1, 2002 07:56 PM
