Best mini me swap for a d15 block?
I got an HF block.. Is there a vtec head i can put in
that would be best on this block?
If so, What do i need to make this mini me swap?
Or should i just go with a Zc...I can get one for 150.
this site shows that the dx and hf block are the same http://www.crxsi.com/specs.htm
but the hf has a higher compression ratio.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivanson »</TD></TR><TR><TD CLASS="quote">I got an HF block.. Is there a vtec head i can put in
you cant put a 16 valve head on a hf block...well you can if you put some diffrent pistons in it..
</TD></TR></TABLE>you cant put a 16 valve head on a hf block...well you can if you put some diffrent pistons in it..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivanson »</TD></TR><TR><TD CLASS="quote">by the Zc i meant i could get a Zc head and block...
everything on it except for the tranny and wiring harness</TD></TR></TABLE>
Assuming you mean a DOHC ZC, then go with the ZC. If you really want to do a mini-me, I would highly suggest using a different bottom end.
SohcVtecCrix
Oct 15, 2002 07:10 AM
crxfanatic
Apr 29, 2002 10:11 AM
