D17 in a EK
Old Mar 8, 2005 | 05:40 PM
Lmgrcivic's Avatar
Default D17 in a EK
does anyone know if this motor fits in a EK the same as a D16 does wasnt sure if they mounted up the same couldnt find anything in the search only found out about using the crank
Old Mar 8, 2005 | 05:45 PM
Luserkid's Avatar
Default Re: D17 in a EK (Lmgrcivic)
I believe they do, but wiring is different.
Old Mar 8, 2005 | 06:07 PM
Lmgrcivic's Avatar
Default Re: D17 in a EK (Luserkid)
anybody know what wiring I have to use
Old Mar 8, 2005 | 06:08 PM
Koyoloeor's Avatar
Also......does anyone know what the numbers are for the D17 motors...hp, torque, etc..thanks
HXMan's Avatar
Just a guess....but I bet the wiring will have to be mostly all custom.
Old Mar 8, 2005 | 06:15 PM
Luserkid's Avatar
Default Re: D17 in a EK (CfS2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CfS2000 &raquo;</TD></TR><TR><TD CLASS="quote">Also......does anyone know what the numbers are for the D17 motors...hp, torque, etc..thanks</TD></TR></TABLE>
D17A1 1668 115@6100 110@4500 9.5:1 75 94.4 sohc no 2 2001+ Civic DX/LX
D17A2 1668 127@6300 114@4400 9.9:1 75 94.4 sohc yes 2 2001+ Civic EX
Old Mar 8, 2005 | 06:34 PM
^CX_d16's Avatar
why do u wanna put a d17 in there?
Old Mar 8, 2005 | 06:36 PM
Lmgrcivic's Avatar
Default Re: D17 in a EK (^CX_d16)
just found one for pretty cheap and for something to do just wanted to be different just wanted to see how hard it would be
Old Mar 8, 2005 | 06:44 PM
pdiggitydogg's Avatar
you know the d16 is better though, right?
Old Mar 8, 2005 | 06:55 PM
egOt's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">you know the d16 is better though, right?</TD></TR></TABLE>
Yea..the d17 is like the black sheep of the d-series family, but hey if you can get the swap done for cheap then go for it. The motors still new so theres not much out there. I did see that theyve been doing y8 IM swaps on the d17 however. So slap on the y8 IM and turbo that bitch.
Old Mar 8, 2005 | 06:56 PM
bgoetz's Avatar
The only reason that I can think of that the d16 would be better would be the OBD1 ecu and the fact that you can Hondata it. Other than that the d17would have .10L more displacement and so no it is not better
Old Mar 8, 2005 | 07:00 PM
bgoetz's Avatar
Default Re: (bgoetz)
Sorry as far as the actual swap goes the chasis is different so you would have to have different engine mounts (big reason why you don't see d17 to B swaps). This would be a bitch to custom and/or cost you alot of $ to buy. You would also have to get the ECU and axles as well. SO you would gain a bit (newer engine and Vtec), but it is a difficult swap. A b swap would cost the same and = more hp
Modified by bgoetz at 5:53 AM 3/9/2005
Old Mar 8, 2005 | 07:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgoetz &raquo;</TD></TR><TR><TD CLASS="quote">the d17would have .10L more displacement and so no it is not better</TD></TR></TABLE>
Woopity doo
The only thing the d17 is good for, if you ask me, is fuel economy
Tiny pistons, plastic intake manifold...yeah, its "better"
Old Mar 8, 2005 | 07:51 PM
.BigSexy's Avatar
most hood white kid
plastic IM?? damn, what is the world coming to?
Old Mar 8, 2005 | 08:17 PM
bgoetz's Avatar
Default Re: (egcoupe94)
dude, they make the same hp to the crank. I would make my entire engine out of plastic if it worked that would be a very light engine
Old Mar 8, 2005 | 08:39 PM
snoochtodanooch's Avatar
d17 is a returnless fuel system, i would see it being a big problem.
Old Mar 8, 2005 | 08:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgoetz &raquo;</TD></TR><TR><TD CLASS="quote">dude, they make the same hp to the crank. I would make my entire engine out of plastic if it worked that would be a very light engine</TD></TR></TABLE>
O MY........
Old Mar 8, 2005 | 08:51 PM
bgoetz's Avatar
as far as the tinny pistons go they have close to the same compression so there is no difference. And the plastic engine that is what you would call a JOKE, but a plastic manifold does not hurt anything unless you want to crank your CAI down to 100+ trq lbs
Old Mar 9, 2005 | 05:49 AM
gabspeed's Avatar
Default Re: D17 in a EK (snoochtodanooch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">d17 is a returnless fuel system, i would see it being a big problem. </TD></TR></TABLE>
Yes sir i second that, nothing but problems. sell that d17 and get a at least a b16 or something you wont regret it
Old Mar 9, 2005 | 05:54 AM
Soccerking3000's Avatar
Default Re: D17 in a EK (gabspeed)
uhhh the d16 is better than the d17 for performance period, there is barely any aftermarket support for that motor, and lots of the d16 parts wont fit on the d17 such as exhaust manifolds, you can't use hondata or uberdata with the ecu and the compression is higher than optimal for boost. But hey it must be better because it has more power STOCK at the CRANK
Old Mar 9, 2005 | 08:08 AM
shifty35's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabspeed &raquo;</TD></TR><TR><TD CLASS="quote">
Yes sir i second that, nothing but problems. sell that d17 and get a at least a b16 or something you wont regret it </TD></TR></TABLE>
That's garbage, people swap K-series (returnless) into EG/EK all the time. You just need an adjustable FPR to connect the return line to.
Old Mar 9, 2005 | 03:04 PM
Lmgrcivic's Avatar
Default Re: D17 in a EK (shifty35)
I didnt have one yet I was just throwing out options thanks for the info I will steer clear of the D17
jase ek
Sep 27, 2005 01:48 PM
zerogravitycrx
Sep 14, 2005 12:19 AM
BritishBulldog
34
Aug 4, 2005 03:48 PM
MB4
Mar 7, 2004 08:48 PM
