Still a Noob...What is mpfi and dpfi..
Old Mar 8, 2005 | 05:35 PM
ivanson's Avatar
Default Still a Noob...What is mpfi and dpfi..
I always see people saying i did my 'mpfi conversion'
Is this a good thing???
Is this for your ecu to support more hp?
How do i identify if i have mpfi or dpfi???
reply back thanks
Old Mar 8, 2005 | 05:44 PM
CRX_LSVTEC's Avatar
Default Re: Still a Noob...What is mpfi and dpfi.. (ivanson)
dpfi
is dual point fuel injection 2 injectors....carb style....this is the .dx model
and the si has mpfi multi point fuel injection 4 injectin, fuel injected.....
92hp or 108hp, there are other things that factor in but that is the biggie
Old Mar 8, 2005 | 05:50 PM
njn63's Avatar
the mpfi injects the fuel closer to the cylinders also which is a much better setup. It also breathes better, and.... i dunno, i never really thought about it much because i just knew it was better.
Old Mar 8, 2005 | 05:51 PM
njn63's Avatar
oh, and MPFI will have 4 fuel injectors close to where the intake meets the head. DPFI will not as they are up by the throttle body.
Old Mar 8, 2005 | 06:13 PM
ivanson's Avatar
thanks....So im good with my hf....its 4injectors
Old Mar 8, 2005 | 09:55 PM
CRX_1.8T's Avatar
Well, you would be better off with the engine from a CRX Si, it is 108 hp compared to the HF's 63 hp or whatever.
k_vd16
Feb 13, 2011 07:15 PM
bluelsvtecda9
Mar 11, 2007 02:56 PM
RacinMasonC
Nov 16, 2003 07:53 PM
HondaDreamz
Oct 2, 2003 07:21 PM
Iceycrx
Mar 14, 2002 05:44 AM
