Rear mount needed for ls into eg?
Old Mar 8, 2005 | 04:35 PM
Spence's Avatar
Default Rear mount needed for ls into eg?
hey guys i have searched and no luck but i need to know what mount i need for the rear for a ls into a eg. Which ones will work???
Old Mar 8, 2005 | 04:48 PM
ALLMOTA92EG's Avatar
any b series mount or use the stock one of the ls
Old Mar 8, 2005 | 04:54 PM
WrongWD's Avatar
actually the rear mount is the same, keep the eg one. you just need the rear brace, the t shaped bracket off of the LS
Old Mar 8, 2005 | 05:01 PM
Spence's Avatar
i dont have the t shaped bracket also i have a 98 y8 in the car right now i just need to buy a mount wondering which one
Old Mar 8, 2005 | 05:48 PM
Timmay's Avatar
Default Re: (Spence)
the mount you keep stock it bolts to the subframe
as for bracket to the mount
94-00 integra gsr/ls
94-95 del sol vtec should work
99-00 SI will not work
Old Mar 8, 2005 | 05:58 PM
Spence's Avatar
so the y8 motor mount will work i need a bracket that bolts to the motor then?
Old Mar 8, 2005 | 06:09 PM
Timmay's Avatar
i dont understand what y8 mount you are talking about
the stock rear mount that hooks to the car should not be taken off unless for a h22a or k20
Old Mar 8, 2005 | 06:28 PM
Spence's Avatar
the rear mount that is already there? i need the bracket of a b series?
Old Mar 8, 2005 | 09:23 PM
Spence's Avatar
Default Re: Rear mount needed for ls into eg? (Spence)
bump i need to know
Old Mar 8, 2005 | 09:30 PM
JDMlyfestyle's Avatar
here you go bro.. my write up should help you
https://honda-tech.com/zerothread?id=983454
deemy72
Aug 30, 2009 01:49 PM
Tjames8864
Jan 16, 2007 06:20 PM
nicknasty
Nov 19, 2003 02:30 PM
lowboost civ
Mar 9, 2003 07:23 PM
B18B EK
Nov 20, 2002 02:33 PM
