What Brand And Size ThrottleBody For Mild GSR ?
Hey, whats the deal ........ wanted to know what throttlebody would be a good size to get for my hatchy with a gsr swap ...... SO far I Have
Intake , exhaust , headers, port and polished skunk 2 mani , type r cams , s-vafc?
would a 68 mm skunk 2 be a good fit ? Im planning on going turbo in a couple months so i want something that will allow me to expand .... Thanks
I heard maxbore .... is known on honda-tech .... any people satisfied with their work ? thanks in advance
I got one maxbored JDM type R 70mm throttle body.
check it out here:
https://honda-tech.com/zerothread?id=1163220
check it out here:
I just bought a STR 65mm throttle body, fits perfect to my skunk2 manifold. Anything bigger you have to have your skunk manifold widened or port matched as i have been told. If your going turbo in the future, put your GSR cams back in, and get yourself a 68mm or 70mm throttle body
You should have just bored out your stock TB to 64mm and got it port matched to your skunk2 IM which has a inlet of 64mm. Since you went with a 65mm you now have a bottleneck, just like when you have a 2.5in header matched with a 2.38in exhaust.
I just saw that your going turbo, if thats the case you should go with a IM that has a large plenum but small runners. And you should also port match your TB.
boostd ls
Mar 22, 2008 01:40 PM
wushubrian
Jan 26, 2005 07:23 PM
