Spoon calipers with stock brake pads - need modification?
Old Mar 8, 2005 | 01:07 PM
R249's Avatar
Default spoon calipers w/ OEM brake pads
anyone using spoon calipers w/ OEM brake pads? if so, is there a little modification that I have to do?
Old Mar 8, 2005 | 01:09 PM
Chris93Si's Avatar
Default Re: spoon calipers w/ OEM brake pads (R249)
Shouldn't require any modification
If your gonna spend that much on calipers why run stock pads?
Old Mar 8, 2005 | 01:11 PM
thk's Avatar
thk
Members Only
Default Re: spoon calipers w/ OEM brake pads (Chris93Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si &raquo;</TD></TR><TR><TD CLASS="quote">Shouldn't require any modification
If your gonna spend that much on calipers why run stock pads?</TD></TR></TABLE>
Bzzt.
You're going to have to rip off the "wear indicators". You know, those metal strips that's on the "inside" pad. But other than that, you're good to go.
SoCal ITR's Avatar
I agree, stock pads suck in my opinion. At least try out some ultimates or HP+.
Old Mar 8, 2005 | 01:12 PM
Chris93Si's Avatar
Default Re: spoon calipers w/ OEM brake pads (thk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">
Bzzt.
You're going to have to rip off the "wear indicators". You know, those metal strips that's on the "inside" pad. But other than that, you're good to go.</TD></TR></TABLE>
me = owned
Old Mar 8, 2005 | 02:05 PM
Mr. Roboto's Avatar
fo'real
Old Mar 8, 2005 | 02:07 PM
Black R's Avatar
25 Year Member
Bzzt.
yup, I run stock pads for street on my spoon calipers. stock are great street pads. you will need to tear off the metal tabs and grind them down flush to make sure they fit properly.
Old Mar 8, 2005 | 03:24 PM
Kicker773's Avatar
Default Re: spoon calipers w/ OEM brake pads (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">yup, I run stock pads for street on my spoon calipers. stock are great street pads. you will need to tear off the metal tabs and grind them down flush to make sure they fit properly. </TD></TR></TABLE>
nothing is wrong with running stock pads...hell they had a lot of meat on them when i switched to the blue spoomies but when they're used up i'll go aftermarket...but i dont c y u guys are hatin on oem hehehe
Old Mar 8, 2005 | 03:55 PM
Viper8L488's Avatar
Default Re: spoon calipers w/ OEM brake pads (Kicker773)
I agree. I have crossdrilled/slotted rotors and stainless steel lines as brake upgrades on my civic, and I like the OEM pads better for street use than any aftermarket pad I have used (Hawk and Porterfield).
OEM
Old Mar 8, 2005 | 04:10 PM
1GreyTeg's Avatar
Default Re: spoon calipers w/ OEM brake pads (Viper8L488)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Viper8L488 &raquo;</TD></TR><TR><TD CLASS="quote">I agree. I have crossdrilled/slotted rotors and stainless steel lines as brake upgrades on my civic, and I like the OEM pads better for street use than any aftermarket pad I have used (Hawk and Porterfield).
OEM </TD></TR></TABLE>
Show car?
Old Mar 8, 2005 | 04:13 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 &raquo;</TD></TR><TR><TD CLASS="quote">but i dont c y u guys are hatin on oem hehehe </TD></TR></TABLE>
They suck at the track, in a lot of our experience.
nsxtasy would differ.
-Chris
Old Mar 8, 2005 | 04:20 PM
1GreyTeg's Avatar
Default Re: spoon calipers w/ OEM brake pads (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
Never tracked them but I had great experience with them for daily and autocross. Plus they don't dust or at least close to nothing.
Old Mar 8, 2005 | 05:19 PM
jdmspoonitr's Avatar
Default Re: spoon calipers w/ OEM brake pads (1GreyTeg)
I am going to use my stocks on the street with my spoons too. It's not like you can't switch them out for track days or anything. rofl. Or do you all like pads that won't give u any cold braking on the street???
Old Mar 8, 2005 | 07:06 PM
TPB's Avatar
TPB
Default Re: spoon calipers w/ OEM brake pads (jdmspoonitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote"> Or do you all like pads that won't give u any cold braking on the street??? </TD></TR></TABLE>
Do you honestly think that aftermarket pads do not work well until they have some heat in them? There are plenty pads that do a phenomenal job of braking on the street even when freezing outside. Unfortunately a lot of them do dust a lot such as HP+.
Old Mar 8, 2005 | 07:18 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">nsxtasy would differ.</TD></TR></TABLE>
About everything
Old Mar 8, 2005 | 08:01 PM
Chris F's Avatar
Default Re: spoon calipers w/ OEM brake pads (TPB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TPB &raquo;</TD></TR><TR><TD CLASS="quote">
Do you honestly think that aftermarket pads do not work well until they have some heat in them? There are plenty pads that do a phenomenal job of braking on the street even when freezing outside. Unfortunately a lot of them do dust a lot such as HP+.</TD></TR></TABLE>
I rock Cobalt Spec VR's on the street. w00t. They actually quiet down a lot for a week after HPDE, then get loud again.
Old Mar 8, 2005 | 08:02 PM
uNF$@#!'s Avatar
Bzzt.
harder than it seems! I had to drill mine off
Old Mar 8, 2005 | 08:09 PM
n2civicsi's Avatar
Default Re: spoon calipers w/ OEM brake pads (255.255.255.255)
i was thinkin bout this setup on mined
Old Mar 8, 2005 | 09:08 PM
thk's Avatar
thk
Members Only
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">harder than it seems! I had to drill mine off </TD></TR></TABLE>
Odd. I just stepped on the pad and yanked it off with a pair of pliers.
Old Mar 9, 2005 | 01:19 AM
DC2IntegraTypeR's Avatar
Kinda OT: but I think I learned something new today?
I never knew that stock brake pads could fit Spoon calipers...so the same sized pads for ITR calipers will fit Spoon 4 pot calipers also?
If so, I guess I will be getting them sometime down the road then
Modified by RisforTypeR at 3:03 AM 3/9/2005
Old Mar 9, 2005 | 05:04 AM
RagingAngel's Avatar
Default Re: (RisforTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RisforTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Kinda OT: but I think I learned something new today?
That was one of the design criteria that Spoon spec'd .....that an OEM sized/dimension pad could fit into their caliper.
So one wouldn't be stuck with ordering specific shapes or sizes...although with today's comprehensive aftermarket lines, it's doubftul you cannot find anything you need.....
I rock the OEM pads on the Spoon stoppers..... for when the car comes off the track.... the Endless MA11s I use on track eat up rotors .....stock is great on street
Old Mar 9, 2005 | 07:48 AM
Black R's Avatar
25 Year Member
haha, yeah you have to use a dremel to take off those weird rivet thingies that stay on even after you rip off the metal tabs.....
Old Mar 9, 2005 | 07:51 AM
m R g S r's Avatar
OT, but how much are spoon calipers?
Old Mar 9, 2005 | 09:12 AM
1GreyTeg's Avatar
Default Re: spoon calipers w/ OEM brake pads (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">OT, but how much are spoon calipers? </TD></TR></TABLE>
around about $1.5G
Old Mar 9, 2005 | 09:39 AM
JDM Factor's Avatar
I had the spoon rotors, ran crappy AEM pads, which completely glazed the rotors, stupid on my part, but I'll never buy a slotted rotor for the street again. The most annoying noises ever created by those things. GT Sports and AutoZones for me!
