Skunk 2 Stage 2 Shafts
Old Mar 8, 2005 | 11:58 AM
milton's Avatar
Default Skunk 2 Stage 2 Shafts
I have had my stock lsvtec for a while and wanted to try to use some sk2 st II. I looked for more info but couldnt get any good ones.
I have a stock bottom block, and wanted to just slap on valves, valvesprings, and sk2 st II camshafts.
I know it needs more compression ( I have a set im my other car ). Will this make any power at all? Because I really didnt want to tear up the bottom block just yet, I wanted to see what this can do?
Anyone has done this? Thanks in advance
Old Mar 8, 2005 | 12:17 PM
DavidT or VajT's Avatar
Default Re: Skunk 2 Stage 2 Shafts (milton)
Bigger lift and duration always makes more power. You'll feel the power even without high compression especially with the s2s2's, but your car will have better response with higher compression. Forget compression dude, it's all in TUNING!
Old Mar 8, 2005 | 02:06 PM
jdmoutkast's Avatar
RM22's
Old Mar 8, 2005 | 03:02 PM
ek2k's Avatar
one time i called skunk2 to ask what is the compression needed to run these cams and they told me anything above 11 is fine but the more the merrier so good luck and hopefully you like it.
-1 hundred
Old Mar 8, 2005 | 04:22 PM
philafelman's Avatar
Default Re: Skunk 2 Stage 2 Shafts (ek2k)
i have them with 11.5:1 compression-they make good power-im hittin around 200whp untuned.
Turbofrancis619
Sep 4, 2008 06:18 AM
EriK20
13
Apr 10, 2004 09:19 AM
Soon_2b_evil
Nov 16, 2003 07:41 PM
gsrvx
23
Sep 13, 2003 08:18 AM
Crossett
Dec 3, 2001 06:41 AM
