FS: 92 Hatchback Built B16, Type-R tranny, Track prepped
Edit 3/20/05:
-Head is at machine shop being prepped for new crower cams. Is getting new rockers and valve springs. Car will be running in roughly 3 weeks. Will receive new bearings on the crank and rods when put back together. Will need break in miles.
-Car is NOT street legal. You take your own risk if you drive it on the street.
-Car does NOT have street legal exhaust.
-Car does NOT have an interior besides dash shell & door panels. Everything else has been removed.
-This for all intensive purposes is a race car.
PM Me for more. Make me an offer. No lowballers. Serious inquires only please. Looking to sale for reasonable price.
1992 VX Hatchback
-2 Blocks
-1 OEM
-1 with .25mm Over CTR Pistons
-Cams TBD (probably Crower Stage 3)
-Dual Valve Springs with Titanium Retainers
-ST Corsa Shoulder Lock Cam gears
-Head has race port and polish & Milled .010"
-Custom Headers designed for High RPM Power (see pic)
-Mugen Head Gasket
-Greddy Timing Belt
-All new bearings (block with ctr pistons)
-Type-R oil pump (600 miles)
-ARP studs and bolts inside (everything)
-CTR pulley
-Skunk 2 Intake manifold
-Hondata Heat Shield Gasket
-Crane Cams Igntion Set (Capacitve)
-Ultra 8 Spark plug Wires
-OBX FPR
-Greddy Catch Can
-Custom Oil Cooler setup with Braid hoses
-AEM Fuel Filter with Earl's Braided Hose
-Venow 270cc Injectors
-GSR Calipers
-Project Mu Pads
-Brembo Rotors
-Earls Stainless Braided all 4 corners
-Braided Clutch Line
-JDM Rear Disc Conversion
-ALL Bushing upgraded to Energy Poly-Urathane(sp?)
-Eibach Sway bars (Front and Back)
-All GSR Suspension Arms (if it matters)
-Blitz Intake filter
-Alum 1.5 inch dual row radiator (only water and water wetter)
-P28 ECU (running P30 code) needs tuning, will throw in software to tune with
-Fields VTEC Controller (Should only used for minimal track side adjustments)
-S80 Type-R Tranny WITH OEM LSD with less then 1000 Miles (NEVER RACED)
-ACT Flywheel
-Clutchnet Carbon Fiber Clutch and 1X Pressure plate
-Carbon Fiber Strut Tower Bar
-No Names in back (upper and lower)
-Ground Control Coil-overs
-HammerHead Carbon Fiber hood (weighs 2.5 lbs and has 4k twill weave. 1 OF 3 MADE!)
-OMP Seat
-Sparco 4 point (passenger)
-RJS 5 point (driver)
-5 Inch tach with recall and shift light
-Gauges (oil pressure, water temp, Exhaust temp, Volt)
Car is gutted. Nothing except the dash shell is left. No heater or anything thing else. The door panels are in also.
Probably more just can't remember.
Also need to mention that it is registered with BAR to legally have a B16A. So if you buy the shell, you can throw in a stock b16 and smog it and it will be 100% legal. Sticker is still inside engine bay (protected).
Hate to see her go. She has been a great bitch to me for 5 years.
Does NOT come with those rims.
PM Me for more. Make me an offer. Will not part out (yet).
Modified by qi_doy at 5:19 PM 3/20/2005
1992 VX Hatchback
-2 Blocks
-1 OEM
-Mugen Head Gasket
-Greddy Timing Belt
-CTR pulley
-OBX FPR
-Greddy Catch Can
-GSR Calipers
-Project Mu Pads
-Brembo Rotors
-ACT Flywheel
-OMP Seat
all_motor_mike
Jun 11, 2011 05:44 PM
devnull
Dec 30, 2008 07:03 PM
xpsonic
Jan 17, 2005 12:45 AM
