Need hubcentric rings for TE-37 - hub size?
Old Mar 8, 2005 | 09:05 AM
Blue-Civic-Hybrid's Avatar
Loved
Default ITR hub Centric rings for Volk TE-37s... hub size questions..
I would just like to know the hub centric ring size needed for a USDM ITR 5 lug setup on 15x6.5 Volk TE-37s with a +39 offset. I saw some posts in the archived section and I noticed my Volks seem to have a set of rings in them but they are off kilter. If anyone knows the measurements off the top of thier heads it would be awesome.
Correct me if I am wrong, but aren't the hub centric rings supposed to stay on the hub rather than the inner part of the wheel correct?
I know this has got to be a problem because I have gotten my TE37s balanced twice and I still have a very noticeable vibration at speeds over 65-70mph. I also retorqued everything and checked my wheel bearings and my old ITR OEM wheels display no such vibration.
Also, any info on local tire places that carry these rings in San Diego would be greatly appreciated.
Old Mar 8, 2005 | 09:18 AM
.RJ's Avatar
.RJ
Default Re: ITR hub Centric rings for Volk TE-37s... hub size questions.. (Blue-Civic-Hybrid)
Solution - remove the hubcentric rings. Seriously.
With the car in the air, put the wheels on and torque the lugs to 40-60 ft lbs to seat them. Drop the car down, torque them to whatever spec you are using. I have never run stupid hubcentering rings and never had an issue.
Old Mar 8, 2005 | 09:34 AM
jdmvtec28's Avatar
The center bore for the ITR, and all other tegs for that matter is 56mm...
Old Mar 8, 2005 | 09:38 AM
Chris F's Avatar
Default Re: ITR hub Centric rings for Volk TE-37s... hub size questions.. (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Solution - remove the hubcentric rings. Seriously.
Yeah, just get some torque on the lug nuts while in the air (like .RJ mentioned). Or torque them all the way while in the air, that's what I do.
-Chris
Old Mar 8, 2005 | 09:49 AM
Loved
Thank you for the reply, but I really think i need those hub centric rings to get the rims to fit properly against the hub....
Thanks for the 56mm info...
Old Mar 8, 2005 | 09:51 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue-Civic-Hybrid &raquo;</TD></TR><TR><TD CLASS="quote"> but I really think i need those hub centric rings to get the rims to fit properly against the hub.... </TD></TR></TABLE>
Thats what I'm telling you. You do not need the rings, and they are likely only causing a problem for you.
Old Mar 8, 2005 | 09:58 AM
Loved
Alright, I'll try it and see if the problem goes away. If not, then probably I will have to see what else could be causing the problem... torque will be the answer at 90ft/lbs.
Old Mar 8, 2005 | 12:38 PM
Bbasso's Avatar
For three years I have rims that could use them but never once used the centric ring and not one problem.
Old Mar 8, 2005 | 03:35 PM
Loved
Default Re: ITR hub Centric rings for Volk TE-37s... hub size questions.. (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">For three years I have rims that could use them but never once used the centric ring and not one problem.</TD></TR></TABLE>
What types of rims?
Old Mar 8, 2005 | 03:37 PM
Haleiwa-Brando's Avatar
I've got Volk 57s wheels, no rings....they are fine.
Old Mar 8, 2005 | 09:08 PM
jdmvtec28's Avatar
Were the Volks you have originally designed for Integras, or was the fitment for something else facilitating the need for the hub rings?
Old Mar 9, 2005 | 05:44 AM
.RJ's Avatar
.RJ
Default Re: ITR hub Centric rings for Volk TE-37s... hub size questions.. (jdmvtec28)
Aftermarket wheels arent designed (i.e. hubcentric) for any specific vehicle
Old Mar 9, 2005 | 06:41 AM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue-Civic-Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">What types of rims?</TD></TR></TABLE>
Rota SS.
Old Mar 9, 2005 | 08:10 AM
Agent Daimon's Avatar
i thought hondas were lug centric not hub centric
Old Mar 9, 2005 | 09:09 AM
Drive01's Avatar
I don't know the hub size, but you could just drive into Americas tire co and they'll fit you w/ cheap plastic rings. I say cheap cause they melt at high temp on the track(magazine claimed this) My set haven't melted yet w/ 3 track events. Street use should be fine. I think it was like $10 for all 4. I have TE's as well.
Old Mar 9, 2005 | 12:02 PM
Dan GSR's Avatar
Thanks for the 56mm info... </TD></TR></TABLE>
except he's wrong
civic and integra are the same
ITR is bigger
Old Mar 9, 2005 | 01:44 PM
jdmvtec28's Avatar
Default Re: ITR hub Centric rings for Volk TE-37s... hub size questions.. (Dan GSR)
Then what is it? I'll double check with my wheel tech...
Old Mar 9, 2005 | 03:02 PM
Padawan's Avatar
Darth ModerVader
This is also probably obvious, but are you using the proper lug nuts with the Volk's?
I, like many others who've posted here, have never had a single problem running without rings on my after-market wheels (Rota Slipstream's). I used correctly sized conical seat lug nuts and always torqued them properly with no load, and they always performed flawlessly. I've read and participated in quite a few hub-centric ring threads, and have personally never understood what some individuals' vehement fixation is with them on Honda/Acura vehicles.
Old Mar 9, 2005 | 08:30 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec28 &raquo;</TD></TR><TR><TD CLASS="quote">Then what is it? I'll double check with my wheel tech...</TD></TR></TABLE>
ITR is 64mm
Old Mar 10, 2005 | 05:49 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">ITR is 64mm</TD></TR></TABLE>
wrong again.... 64.1
Old Mar 10, 2005 | 06:01 AM
Black R's Avatar
25 Year Member
fwiw, I have volk and racing hart rims. I use metal hub rings up front and plastic ones in the rear.
I have also run my te37's without rings, but with spacers and never once had a problem either way.
Get a dynamic balancing job done first. Then make sure you torque the wheels in the air. 80ft/lb. That is all.
Any Discount Tire/ America's Tire can do all of the above for you... fyi... including the fitment of hub rings.....
And if you just HAVE to have rings to feel better - any machine shop can make a metal set for you; just tell them what inner and outer bore you need and they'll whip it up on the spot.
Old Mar 10, 2005 | 08:21 AM
Loved
Default Re: ITR hub Centric rings for Volk TE-37s... hub size questions.. (Padawan)
I am using the Volk Racing Lugs extended version. I have been torquing the lugs to 80ft/lbs, but I will first try getting these rings from Discount tire and see if the rims require to be rebalanced. I have metal rings in there right now, but they were ****-eyed and I have straightened them out since, but I didn't notice a difference.
Thanks for all the info about the hub size...it's 64mm right? or 64.1 mm?
Old Mar 18, 2005 | 10:26 AM
Wraith_G2IC's Avatar
You can check this site that I saw recently:
http://www.ezaccessory.com/.sc...Rings
I don't know about the ITR being different but the hub diameter on the Integra is 56.15. You will need to find the proper bore size of the wheel too.
Old Mar 18, 2005 | 10:38 AM
Rodney's Avatar
Default Re: ITR hub Centric rings for Volk TE-37s... hub size questions.. (Wraith_G2IC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wraith_G2IC &raquo;</TD></TR><TR><TD CLASS="quote">I don't know about the ITR being different but the hub diameter on the Integra is 56.15. </TD></TR></TABLE>
as mentioned above numerous times, the itr has a 8mm larger hub bore then the standard integra.
Old Mar 18, 2005 | 04:05 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue-Civic-Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">I am using the Volk Racing Lugs extended version. I have been torquing the lugs to 80ft/lbs, but I will first try getting these rings from Discount tire and see if the rims require to be rebalanced. I have metal rings in there right now, but they were ****-eyed and I have straightened them out since, but I didn't notice a difference.
Thanks for all the info about the hub size...it's 64mm right? or 64.1 mm? </TD></TR></TABLE>
64.15mm j00!
misha
Jul 1, 2009 05:36 AM
Todd00
May 29, 2003 08:47 PM
vactor
May 22, 2003 03:25 PM
RAB
14
Sep 19, 2002 04:45 PM
speedjunkeez
Jun 5, 2002 01:51 PM
