Storing the Battery
Old Mar 8, 2005 | 08:20 AM
B2FiNiTY's Avatar
Default Storing the Battery
I plan on removing my battery and won't be using it at least half a year. Are there any storage processes so that the battery does not get ruined from sitting too long?
Old Mar 8, 2005 | 08:27 AM
Collateral's Avatar
B A N N E D
Default Re: Storing the Battery (B2FiNiTY)
Put in the freezer
Old Mar 8, 2005 | 08:32 AM
cmdr430's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I plan on removing my battery and won't be using it at least half a year. Are there any storage processes so that the battery does not get ruined from sitting too long? </TD></TR></TABLE>
do you have access to any kind of trickle charger......
that is what i would recommend......
Old Mar 8, 2005 | 08:38 AM
Bbasso's Avatar
http://www.ibsa.com/www_2001/c...g.htm
http://in.classifieds.yahoo.co....html
http://www.autobatteries.com/b...e.asp
http://www.batteryuniversity.com/partone-19.htm
Old Mar 8, 2005 | 12:14 PM
rovigian's Avatar
Unless it is an expensive one, just replace it. Batteries should be replaced every 3 years.
Old Mar 8, 2005 | 12:21 PM
TPB's Avatar
TPB
Default Re: Storing the Battery (rovigian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rovigian &raquo;</TD></TR><TR><TD CLASS="quote">Unless it is an expensive one, just replace it. Batteries should be replaced every 3 years.</TD></TR></TABLE>
&lt;slaps forehead&gt; Wow, if only I had known! No truer words of interweb wisdom have I heard before
I've had the same battery since '97 and I've been storing it 7 months at a time for the last 5 years. All you need to do is keep it in a warm dry place and before you are ready to reinstall it, charge it slowly using a trickle charger.
Old Mar 8, 2005 | 12:26 PM
JettaRacer's Avatar
Default Re: Storing the Battery (TPB)
The isht.
http://www.ctek.se/ctek_multixs3600_gb.htm
Old Mar 8, 2005 | 12:31 PM
Bbasso's Avatar
I would like to see how you came up with this info.
Old Mar 8, 2005 | 12:35 PM
TPB's Avatar
TPB
Default Re: Storing the Battery (Bbasso)
Check this out for your charging needs : http://www.batterytender.com
Modified by TPB at 1:55 PM 3/8/2005
Old Mar 8, 2005 | 01:09 PM
IGGY's Avatar
You have to charge them every once in a while or else they will go bad.
Old Mar 8, 2005 | 01:35 PM
JDM2ndGen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">
I would like to see how you came up with this info.</TD></TR></TABLE>an Autozone commercial ...
Old Mar 8, 2005 | 06:35 PM
rovigian's Avatar
Honda service manual
Old Mar 8, 2005 | 07:40 PM
Bbasso's Avatar
Tomorrow or when I get a chance to brave -5 deg weather I'll go and read the manual.
