Removing the Front Brake Rotors
Old Mar 8, 2005 | 07:17 AM
txwylde's Avatar
Default Removing the Front Brake Rotors
I was trying to remove my rotors to have them turned because my steering wheel shimmies around 65 miles an hour and I hit my brakes. I removed the caliper, the pads, and the holder for the pads but was surprised when the rotor wouldnt just come off. Do I need to beat it with a hammer to get it to come off? What is the trick to removing the rotors?
Thanks!
Bill
Old Mar 8, 2005 | 07:33 AM
jweller's Avatar
Default Re: Removing the Front Brake Rotors (txwylde)
what year
Old Mar 8, 2005 | 07:55 AM
txwylde's Avatar
Default Re: Removing the Front Brake Rotors (jweller)
2004 Accord EX, 4 wheel Disc brakes.
Old Mar 22, 2005 | 12:34 PM
Jumper's Avatar
Did you get those rotors off? I did the rear pads on my 03 but I need to do the fronts and I'm trying to find the best price on new rotors, the originals have been turned once and I doubt they will have enough meat to do them again.
Old Mar 22, 2005 | 03:56 PM
govtec's Avatar
Default Re: Removing the Front Brake Rotors (Jumper)
it's probably the wheel bearing that is holding it in tight. ur going to need a press to get it out or other old fashion option a slide hammer. mines was a bitch to get off because it corroded and sealed itself to the rotors but mines is a 95.
Old Mar 22, 2005 | 04:35 PM
pumafeet10's Avatar
depends on what year it is if its a 5gen u have to remove the hub and spindle and have the rotor pressed off and then milled.
Justin Meiring
Oct 14, 2014 08:41 AM
gohonda
May 14, 2009 02:40 PM
ajtaccord
Aug 13, 2007 03:09 PM
EK9 BEEZLER
Jul 25, 2005 04:44 AM
TsunamiZC
Oct 7, 2002 01:40 PM
