Timing Belt Question
Old Mar 8, 2005 | 05:18 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Timing Belt Question
I read poison faq, and basically understand everything that needs to be done.
How ever, when making sure your camshaft is at tdc, if it isn't do you take off the camshaft pulley and then reorganize it so that you have the up and top dead center?
thanks just wanted clarification
Old Mar 8, 2005 | 05:33 AM
4drmadness's Avatar
On the Cam gear there is the marks for TDC..Rotate that to get the cam set to TDC..
Hope this helps..good luck..
Old Mar 8, 2005 | 10:09 AM
MugenHonda's Avatar
Default Re: (4drmadness)
so before I take off the crank, rotate it the crank till the cam gear is at tdc??
thanks
Old Mar 8, 2005 | 10:57 AM
2lua's Avatar
Default Re: (MugenHonda)
yes, you should be sure the crank and cams at tdc before you remove or losen the timing belt, and recheck the crank and cams again for tdc before and after you replaced the timing belt.
Old Mar 8, 2005 | 12:36 PM
MugenHonda's Avatar
Default Re: (2lua)
thanks for the help
Old Mar 8, 2005 | 12:41 PM
95excoupe's Avatar
Just be extra careful you aren't a tooth off or anything cause it sucks to have to do it again twice. Also, make sure you have the tool to get the crank pulley bolt off, otherwise you will be fighting with it a lot more then you have to.
wk9k
Mar 13, 2012 05:45 PM
goota
Aug 22, 2009 07:38 AM
turboedsupe
Sep 19, 2008 04:32 PM
MugenHonda
Mar 15, 2005 03:33 PM
94dxt
Oct 27, 2004 12:36 PM
