i got a 91 crx and using 88 crx doors
Old Mar 8, 2005 | 01:57 AM
V8K1LLER's Avatar
Default i got a 91 crx and using 88 crx doors
i got a 91 crx and using 88 crx doors what do i need to change ??????????????????????????
thansk fo rur help
Old Mar 8, 2005 | 06:45 PM
hirevmaniac's Avatar
Default Re: i got a 91 crx and using 88 crx doors (turbocrx951)
Good luck. If your crx which i think if I remember correctly 90-91's have the seatbelts in the doors. The 88-89's don't. I am in need of a pass. door for a 90 crx si right now, because of this. The only thing I can think of is if you weld the piece of door that is at the end of the window that holds the seat belt bolts on the 88 door. I am not sure this will work, you may need to change the glass too. Let me know how you make out. peace.
Old Mar 8, 2005 | 11:22 PM
thatbluecrx's Avatar
the "door ding" moldings are different i believe
Old Mar 9, 2005 | 03:16 PM
Default Re: i got a 91 crx and using 88 crx doors (thatbluecrx)
Yea I think they are. You should be able to make the old one's fit.
slowwhitehatch
Jan 31, 2018 02:48 AM
camo_crx
Dec 5, 2005 06:47 PM
SOHC my DOHC
Jun 22, 2005 09:56 PM
