obd-1 ls ecu p74 Pinouts
I have looked at all of the sites linked from honda tech and have not found a ls ecu pinout scematic. I need to find out the postive and negitive signals.
I put a ls in an ek and It will not idle right and sometimes does not respond to the throttle at takeoff. I have no check engine lights. I used a jumper harness and I am trying to double check to see if it was made correctly.
