cable-hydro conversion....the HARD way
Old Mar 7, 2005 | 10:13 PM
crx_pimp's Avatar
Default cable-hydro conversion....the HARD way
I know there are cable to hydro conversions out there, but they seem to utilize the cable and not the hydro, for drivability reasons i would like to run the hydraulic system to engage my clutch. (much easier to push) because i am running an extremely stiff pressure plate (hard on the leg to press the clutch constantly in the city) anyways has anyone heard of or done a full hydraulic system into a 88-91 civic/CRX or someone give me some ideas , maybe i should just get rid of the high strength clutch I dunno, HELP
Old Mar 8, 2005 | 12:47 AM
EsQueue's Avatar
Default Re: cable-hydro conversion....the HARD way (crx_pimp)
I was under the impression that the hydo and cable applied to the shifter not the clutch engagement.
Old Mar 8, 2005 | 06:46 AM
BIG RICH's Avatar
Default Re: cable-hydro conversion....the HARD way (SeaQuake)
I've seen hydro trannys in a couple CRX's. I'd assume it takes some time. you have to mount the clutch resivoir, the clutch master cylinder then plumb everything. the hydro/cable thing deals does have to do with clutch engagement/disengagement. the shifers on crxs/civics/integras are controlled by rods, or what ever you want to call them.
Old Mar 8, 2005 | 09:04 PM
b18bEKcoupe's Avatar
No its the way that the clutch is contorlled. Most hondas use a shaft for shifting if not than cables.
Kannan08
Transmission & Drivetrain
Oct 23, 2011 11:17 PM
Speed_69
Apr 21, 2006 11:00 AM
asmallsol
Aug 9, 2004 08:06 AM
Flexmyrex
Nov 30, 2002 02:36 PM
See Are X
Apr 25, 2002 05:04 PM
