Suspension & Brakes Theory, alignment, spring rates....
OEM springs + not enough sleep = 4x4...
Old Mar 7, 2005 | 09:59 PM
saywhat's Avatar
Default OEM springs + not enough sleep = 4x4...
So I decided to change back to my OE springs on my car due to the rough ride of the ebay coilovers I bought when I was more naive. So I started with the back and grabbed the springs I had set aside a while ago fearing I would have to reinstall them. I put on both the rear springs and set down the car.... Well I think I mixed up the OE fronts with the rears because the wheel gap in the rear is now like 8-9 inches (I will post pics tomorrow). My question is; Do the front and rear OE springs have different rates and lengths? because if not my car has some serious problems now. Also did Honda stamp the springs with anything to tell the front and rear apart? TIA
Old Mar 8, 2005 | 07:53 AM
AutoXer's Avatar
Default Re: OEM springs + not enough sleep = 4x4... (saywhat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saywhat &raquo;</TD></TR><TR><TD CLASS="quote">My question is; Do the front and rear OE springs have different rates and lengths? because if not my car has some serious problems now. Also did Honda stamp the springs with anything to tell the front and rear apart? TIA</TD></TR></TABLE>
Yes, and possibly. The fronts are longer then the rears. I think they may be marked with paint to tell them apart as well, but I'm not certain of that.
Old Mar 8, 2005 | 08:00 AM
veggiemaster's Avatar
lol, you need to talk to D about some omnis now...
and yes, the fronts are very different from the rears.
Old Mar 8, 2005 | 09:51 AM
Tyson's Avatar
the rear springs have a progressive rate. the fronts are linear. theyre easy to tell apart, the rears will have two different spacings between coils. the fronts will be uniform.
honestly, when you go back to stock springs, the ride height will look huge! but, thats just how stock was.
what you WILL need to do is reset your bushings again however, to make sure youre really at the proper ride height. basically, when you have the suspension in place with the wheel still off, loosen ALL suspension bolts, just back them out a few turns. then jack that corner so the weight off the jackstand is completely off. bounce that corner up and down a bit so the bushings settle and THEN tighten everything up.
Old Mar 8, 2005 | 05:44 PM
saywhat's Avatar
Default Re: OEM springs + not enough sleep = 4x4... (Tyson)
I fixed it, and it looks a lot better now, but thought I would post a pic for a good laugh.
Old Mar 8, 2005 | 05:46 PM
Tyson's Avatar
well, what did you do?
Old Mar 8, 2005 | 05:52 PM
saywhat's Avatar
Well, I did put the wrong springs (front) in the back, I just swapped them out after work for the right ones, and it looks very good... compared to the above.
AllmotorGSReg
Apr 23, 2009 05:57 AM
loup05
Mar 1, 2009 06:37 PM
brainglow
Feb 21, 2007 08:51 PM
shanghaining
24
Jun 1, 2006 05:27 PM
DRKSol
Suspension & Brakes
Jun 7, 2005 12:47 PM
