anyone know how to make the original shift light on a crx work again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srv3fender »</TD></TR><TR><TD CLASS="quote">no its an 91 si pm6</TD></TR></TABLE>
Ok,,then you have to run a rpm switch..
There are 5wires for the light..
2 of them are signal wires to light the bulb
Other 2 connect to the dimmer
The 5th wire is not used..Hook up the 5th wire to the rpm switch..And there you go
so the si ecu doesnt have that capability?
it can only be used with a rpm switch
do they carry those at radio shack
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srv3fender »</TD></TR><TR><TD CLASS="quote">so the si ecu doesnt have that capability?
do they carry those at radio shack</TD></TR></TABLE>
No,, only the hf ecu has the control..
I dont know if they have rpm switches at radioshack..Jegs has them for good prices.
Needs to be About 20% Cooler
i read some where that theres a little box on the back of the cluster very simaler to the cruse control box that taped into the tach signal (basicly a rpm swich) and i also remimber reading that it came on at 2300 rpm. but i have been wrong b4... not offen but it has happened
WickidSi
May 19, 2003 12:08 PM
