1990 Honda Civic DX Swap Idea's
Looking to do a swap. What would be a decent price and give me a noticeable power difference? I was told b18b would be pretty cheap and decent. Any other Idea's?
You have alot of choices..Depends how much money you want to spend and if you want vtec or not ,,and how much hp you want,,etc...
You will have to convert to mpfi no matter what motor you choose..Then if you choose a vtec motor you will have to add the wires for vtec..And if you choose you changeover to obd1 or obd2a/b then you will need a jumper harness for your application..
Bolt in-
d16a6
d15b jdm vtec
d16z6
d16y8
Requires mount kit-
b16a sir1,sir2
b16a2,a3,or
b16a1 from europe spec cars
b16b
b17a
b18a/b
b18c,1,2,3,4,5
b20b/z
lsvtec
Poorman's type-r(b18c block/w b16a head)
b20vtec
Bolt in-
d16a6
d15b jdm vtec
d16z6
d16y8
Requires mount kit-
b16a sir1,sir2
b16a2,a3,or
b16b
b17a
b18a/b
b18c,1,2,3,4,5
b20b/z
lsvtec
b20vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">You have alot of choices..Depends how much money you want to spend and if you want vtec or not ,,and how much hp you want,,etc...
Bolt in-
d16a6
d15b jdm vtec
d16z6
d16y8
Requires mount kit-
b16a sir1,sir2
b16a2,a3,or
b16b
b17a
b18a/b
b18c,1,2,3,4,5
b20b/z
lsvtec
b20vtec</TD></TR></TABLE>You forgot the New K-series swap into a EF but then again he did want something with a cheap price but if your on a budet do a D15bvtec.That way your car would be set up for vtec.Seeing you well want more power down the road.And you can make some decent power out of a turbo D15vtec
Bolt in-
d16a6
d15b jdm vtec
d16z6
d16y8
Requires mount kit-
b16a sir1,sir2
b16a2,a3,or
b16b
b17a
b18a/b
b18c,1,2,3,4,5
b20b/z
lsvtec
Needs to be About 20% Cooler
besides the d15b,is there any D series that has VTEC and whats the highest hp of a d series staying SOHC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster »</TD></TR><TR><TD CLASS="quote"> whats the highest hp of a d series staying SOHC.</TD></TR></TABLE>
sohc vtec zc..140hp
sohc vtec zc..140hp
sohc vtec zc..140hp
thx
sohc vtec zc..140hp
thx
Mini-me swap, z6 head = vtec
And for your MPFI wiring conversion - Rywire.com baby
We can modify your DX harness to be MPFI, supply you with VTEC wiring if you chose a VTEC motor, and we have JKOBD OBD0 to OBD1 jumper harnesses in stock as well. We've got your wiring covered.
godofwar81
Dec 29, 2013 08:17 AM
1234567899876543211230
Nov 4, 2006 11:02 PM
