jdm d15b, hf/dx tranny, a6 flywheel, a6 axels?
Old Mar 7, 2005 | 07:58 PM
AZTEKEF9's Avatar
Default jdm d15b, hf/dx tranny, a6 flywheel, a6 axels?
well i did some search but came up a lil confused.....so heres the deal.... i got a ef...with no drive train. i'm getting the jdm d15b vtec. i got a hf/dx trany with the 21 spline. i know the d15b does not come with a flywheel and if it does is from an auto tranny. i got a a6 flywheel and a z6 flywheel. can this set up work...d15b, hf/dx tranny, a6 flywheel and a6 axels? how bout the clutch? what clutch should i use? 88 crx si, hf/dx......? or any hybrid?
Old Mar 7, 2005 | 08:05 PM
AZTEKEF9's Avatar
Default Re: jdm d15b, hf/dx tranny, a6 flywheel, a6 axels? (AZTEKEF9)
i just need my ef running thats all.....and i am out of $$$...
Old Mar 7, 2005 | 08:19 PM
civicdust's Avatar
same boat as you.....
Bump for some answers
Old Mar 7, 2005 | 08:30 PM
Tad's Avatar
Tad
Default Re: jdm d15b, hf/dx tranny, a6 flywheel, a6 axels? (1crx)
pretty sure it all bolts up fine..
dseries are all interchangeable..
but I do know that there are some "black sheep" in the 80's years of dseries that dont bolt up..
so can't say for 100%
Old Mar 7, 2005 | 09:31 PM
Proper's Avatar
Default Re: jdm d15b, hf/dx tranny, a6 flywheel, a6 axels? (Tad)
The a6 flywheel will bolt up fine. I used the same one in my hatch. As for the clutch, you should use a clutch for whatever tranny you are using.
Old Mar 7, 2005 | 10:08 PM
boosted_hatch_216's Avatar
Default Re: jdm d15b, hf/dx tranny, a6 flywheel, a6 axels? (Proper)
i think you have to use the clutch that goes with the flywheel. they have different sized clutches on the si and the dx.
Old Mar 8, 2005 | 12:06 AM
dr_latino999's Avatar
Default Re: jdm d15b, hf/dx tranny, a6 flywheel, a6 axels? (boosted_hatch_216)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_hatch_216 &raquo;</TD></TR><TR><TD CLASS="quote">they have different sized clutches on the si and the dx. </TD></TR></TABLE>
~BUZZER~Wrong.
88 Had 21 Splined clutches, it was in the neighborhood of 200mm.
89 had 20 splines, same clutch diameter.
90-91 had 20 splines, 212mm diameter.
Now you can use a 90-91 Flywheel with 88-89 Clutch/PP combo but not the other way around.
Old Mar 8, 2005 | 06:02 AM
slywfbpsi's Avatar
Default Re: jdm d15b, hf/dx tranny, a6 flywheel, a6 axels? (dr_latino999)
very true. I used my 91dx clutch and flywheel with a 89 si tranny, on my d15b vtec.
Old Mar 8, 2005 | 09:19 AM
AZTEKEF9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">
~BUZZER~Wrong.
88 Had , it was in th21 Splined clutchese neighborhood of 200mm.
so it does not matter if i use a smaller clutch? i have the 90 si flywheel (212mm diameter) but i need the 88 Clutch/PP combo (21 Splined clutchese neighborhood of 200mm)? the tranny that i have is 21 spline. should i get the 88 crx si clutch/pp? or the 88 hf/dx clutch/pp combo? and how about the axels? i have the a6 si axels.
Old Mar 8, 2005 | 12:05 PM
Aragorn's Avatar
http://thenew.gamesbbs.com/~dmoore/tranny.htm
This is where I always end up for this info, and it says that '88 is the total odd ball. You need all '88 stuff, unless you can get a 212mm pp to fit your 21 spline tranny (But, I don't even know if they make such a thing.) You axles should be fine.
MPGIan
Mar 29, 2011 08:20 PM
CRXalwysk8
13
May 3, 2005 07:18 AM
sohcvtec66
Nov 18, 2003 09:49 AM
91hondacrx
Jan 10, 2003 02:38 PM
the DR.
Feb 10, 2002 08:13 PM
