Suspension & Brakes Theory, alignment, spring rates....
suspension question
Old Mar 7, 2005 | 06:18 PM
matthevelli's Avatar
Default suspension question
Ive bought skunk 2 lowering springs from a friend. I put them on my 95 civic hatch but the front end is a little higher then expected. I look at all my friends cars and there front ends are where mine should be(im jelous) i was wondering if the del sol skunk 2 springs are a different spring rate, and that maybe could be my problem. the back is fine but the front is a little too high, and everything is assembled correctly. if someone could help me with that i;d aprecaite it. Thanks
-dave
Old Mar 7, 2005 | 06:19 PM
Default Re: suspension question (matthevelli)
sorry i forgot to metioned, there from a del sol originally.
Old Mar 7, 2005 | 06:29 PM
TeamNextGenChris's Avatar
are you sure you don't have the front an rear springs switched?
are you sure the springs are seated on the front shocks correctly?
are you sure the front shocks are fully slid down into the forks?
is your car still D-series?i guess there's a possibility that the front springs are a little heavier to compensate for the DEL Sol VTECs extra engine weight,although it should be very little difference,if any.did you ever see them installed on the Del Sol before?what trim level was it,and did it also sit high in the front?
Chris
Old Mar 7, 2005 | 06:32 PM
civictildeath's Avatar
Default Re: suspension question (TeamNextGenChris)
del sols have a higher spring rate then the hatches so puttin sol spings on a hatch will result in it sitting higher than usual
edited
Modified by civictildeath at 11:15 PM 3/7/2005
Old Mar 7, 2005 | 06:35 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: suspension question (civictildeath)
If I'm not mistaken, the del sol weighs more than the hatch. Meaning the del sol has more weight to push down the springs, hence they were designed specifically for the del sol. U should always get springs that were made for your car. Even if it fits, doesn't mean that its right.
Old Mar 7, 2005 | 07:05 PM
CooBlueDAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">1) should be in suspension forum https://honda-tech.com/zeroforum?id=54
2) civics have a higher spring rate then the del sols so puttin civic spings on a sol will result in it sitting higher than usual</TD></TR></TABLE>
It was from a sol, on a civic... not the other way around
Old Mar 7, 2005 | 07:14 PM
Default Re: suspension question (CooBlueDAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CooBlueDAB &raquo;</TD></TR><TR><TD CLASS="quote">
It was from a sol, on a civic... not the other way around</TD></TR></TABLE>
ya i wrote it backwards too my bad
Old Mar 7, 2005 | 09:07 PM
apm's Avatar
apm
if you want a nice drop go with coilovers...springs will not give you very good drop
Old Mar 9, 2005 | 02:58 PM
yeah they were originally from a del sol si, its a small difference but i found some one to purchess them and im going to buy myself some new ones, thanks for the help guys.
digitfast10
Aug 14, 2010 06:06 PM
Non-Vtec101
Suspension & Brakes
Jun 13, 2008 12:14 PM
90civichb
15
Apr 1, 2004 08:55 PM
