do you need mounts for 92 integ?
Old Mar 7, 2005 | 05:39 PM
jdm4dr's Avatar
Default do you need mounts for 92 integ?
92 integra do you need motor mounts for 95 gsr swap
Old Mar 7, 2005 | 06:19 PM
Jwbetley's Avatar
Default Re: do you need mounts for 92 integ? (jdm4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm4dr &raquo;</TD></TR><TR><TD CLASS="quote">92 integra do you need motor mounts for 95 gsr swap</TD></TR></TABLE>
What? Is this a question?
Old Mar 8, 2005 | 04:40 PM
matto2413's Avatar
what i think hes trying to say, is i have a 92 teg, if i do a swap with a 95 motor. do i need new motor mounts.And the answer to that question is no. all hondas are b-series.so there for the mounts are the same
Old Mar 8, 2005 | 06:01 PM
Cjsls's Avatar
Default Re: do you need mounts for 92 integ? (matto2413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matto2413 &raquo;</TD></TR><TR><TD CLASS="quote">all hondas are b-series.</TD></TR></TABLE>
no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matto2413 &raquo;</TD></TR><TR><TD CLASS="quote">so there for the mounts are the same</TD></TR></TABLE>
and no.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matto2413 &raquo;</TD></TR><TR><TD CLASS="quote">what i think hes trying to say, is i have a 92 teg, if i do a swap with a 95 motor. do i need new motor mounts.And the answer to that question is no.</TD></TR></TABLE>
if this IS the case.....he needs to reuse the mounts from his 92 teg motor. As the mounts for the 90/93 and the 94+ are different. someone correct me if im wrong but im pretty sure the mounts between the two generations are different.
Old Mar 8, 2005 | 06:14 PM
Tchleung's Avatar
that is correct. the newer generatino moutns ARE different.
Old Mar 8, 2005 | 06:15 PM
Tchleung's Avatar
All he has to do is reuse all his stick mounts and everythnig will sldie in like gravy..
Old Mar 8, 2005 | 06:39 PM
matto2413's Avatar
Default Re: (Tchleung)
i didnt mean that all honda's are b-series.(DOHC)I know theres also D-series(SOHC). i was preferring to intergra's. And i do beleive all intergra's are b-series. And i was always told that all b-series mounts are the same.now that i think about it, I have a 91 teg, and did a motor swap with a 95 GS-R and the mounts were the same
Old Mar 8, 2005 | 07:39 PM
Tchleung's Avatar
That is impossible because the rear mtoor moutns are different. So is the driver side mount. Not sure abotu the tranny mount
Old Mar 8, 2005 | 08:31 PM
AzBlackTeg's Avatar
Use your existing mounts and it'll bolt up fine providing that your using a Cable tranny instead of the Hyrdo Tranny but if you aren't Good Luck converting to Hydro
Old Mar 9, 2005 | 01:29 PM
matto2413's Avatar
Default Re: do you need mounts for 92 integ? (AzBlackTeg)
no im using cable tranny
Old Mar 9, 2005 | 01:38 PM
3.504's Avatar
3 mounts attach to the tranny in DA's, so he'll have to re-use those. as for the side mount, again, reuse the DA's.
DA's and DC's have different engine bays and completly different mounts
Old Mar 9, 2005 | 04:17 PM
Tchleung's Avatar
Default Re: do you need mounts for 92 integ? (3.504)
Yep. If people didn't post false info, we wouldn't have to post the answer more then once as proof. lol.
efrex
Oct 16, 2008 06:12 PM
B16A Hatchback
Aug 29, 2008 04:19 PM
cvaladez2
Mar 21, 2007 05:03 PM
boosted92hatch
10
May 28, 2006 09:23 AM
paidroe454
Jul 10, 2004 07:32 PM
