'95 Accord 4cyl - starts but dies immediately
Old Mar 7, 2005 | 03:23 PM
Yellow Dragon's Avatar
Default '95 Accord 4cyl - starts but dies immediately
Okay I need some help here Honda-Tech. '95 Accord 4dr 4cyl. I can get it to start by pumping the gas pedal and holding the ignition engaged all the way to the START position. When it twists back to accessory position it dies. Also it won't start up without pumping the gas pedal. What do you think is the problem? Any help would be appreciated.
Thanks,
Todd
Old Mar 7, 2005 | 03:34 PM
Slamaccord's Avatar
Default Re: '95 Accord 4cyl - starts but dies immediately (Yellow Dragon)
I really don't think the gas pedal has any efect on the engine b/c of you being fuel injected your fuel is controlled by the ecu. How many miles are on the car? When was your last tune up? Could be a malfuntion with your ignition switch.
Old Mar 7, 2005 | 05:16 PM
h22cord's Avatar
you might need to tune it up, check your wires, and the dizzy
Old Mar 7, 2005 | 08:24 PM
lilman4o8's Avatar
what is a dizzy, or when you guys say replace the dizzy, sorry just trying to learn more. thanks
Old Mar 7, 2005 | 11:24 PM
raceACCORDingly's Avatar
dizzy = distributor
Old Mar 8, 2005 | 09:28 PM
lilman4o8's Avatar
Default Re: (raceACCORDingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">dizzy = distributor</TD></TR></TABLE>
thankz man
Old Mar 9, 2005 | 08:18 AM
Default Re: (lilman4o8)
So are you saying the "dizzy" is bad or maybe it just needs a new cap/rotor.
I had an ignitor go bad in my '92 hatch once.
Old Mar 9, 2005 | 09:53 AM
BaddMo2002's Avatar
could be a bad fuel pump..not pumping enough fuel.
Old Mar 9, 2005 | 10:39 AM
alotawatts's Avatar
Default Re: (BaddMo2002)
I'm with BaddMo2002. test for fuel. Distributor probs are no-start or bad running ?
Old Mar 9, 2005 | 11:25 AM
asianpoet's Avatar
might also be your ignition switch..... Hey its possible, I HAD the same problem with my Integra...
Old Mar 9, 2005 | 12:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BaddMo2002 &raquo;</TD></TR><TR><TD CLASS="quote">could be a bad fuel pump..not pumping enough fuel.</TD></TR></TABLE>
Yeah could be that too. We tried changing the fuel filter first and that BITCH wouldn't come off. WTF!? Anyone have any tips on how to get it off?!
Old Mar 9, 2005 | 12:52 PM
-RedneckDave-'s Avatar
Working
Default Re: (Yellow Dragon)
I would say fuel filter most likely.
Old Mar 9, 2005 | 01:33 PM
Default Re: (-RedneckDave-)
Yes but how do I get it off. LOL.
(BTW, this is Colossus from the JLA forum)
Old Mar 9, 2005 | 01:35 PM
Working
Best bet is to consult the haynes/ Helms manual but it should just be either on there with clamps or a bolt. I took mine off the other day when I pulled my motor.
Old Mar 9, 2005 | 08:35 PM
BaddMo2002's Avatar
dude, to take off that filter..I took it to the shop. I had to pay $70 labor but it was there problem and they did it. They took out the master cylinder and put that to the side for more room (they kept the brake lines connected to the master cylinder). How many miles do your car have? What octane do you usually pump? Do you hear the fuel pump relay?
Old Mar 9, 2005 | 08:54 PM
sj993's Avatar
Might be the fuel pump. I had that problem today when I was parked on an incline with a little bit of gas left in the car. Wouldn't stay running till I got it on level ground.
Old Mar 9, 2005 | 08:57 PM
BaddMo2002's Avatar
Default Re: (sj993)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sj993 &raquo;</TD></TR><TR><TD CLASS="quote">Might be the fuel pump. I had that problem today when I was parked on an incline with a little bit of gas left in the car. Wouldn't stay running till I got it on level ground.</TD></TR></TABLE>
that's normal to be on an incline with little gas left. it's good to keep atleat 1/4 of a tank of gas @ all times so let's say if you are on an incline, your fuel pump doesn't have to work twice as hard.
Old Mar 9, 2005 | 09:36 PM
Default Re: (sj993)
The fuel pump is working. I can hear it unless it's normal to hear it and it's bad. LOL.
Old Mar 9, 2005 | 09:44 PM
sackdz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yellow Dragon &raquo;</TD></TR><TR><TD CLASS="quote">Okay I need some help here Honda-Tech. '95 Accord 4dr 4cyl. I can get it to start by pumping the gas pedal and holding the ignition engaged all the way to the START position. When it twists back to accessory position it dies. Also it won't start up without pumping the gas pedal. What do you think is the problem? Any help would be appreciated.
Thanks,
Todd</TD></TR></TABLE>
Well if it twists back to the accessory position then the car should die, its supposed to switch back to ignition. assuming thats what you meant... check the main PGMFI relay.
Old Mar 10, 2005 | 08:47 AM
alotawatts's Avatar
Default Re: (sj993)
I think fuel pump problems on an incline are usually old mechanical pumps.
Old Mar 10, 2005 | 09:49 AM
Filthy Focker!'s Avatar
Default Re: (alotawatts)
Going around in circles i see. Man, what kind of advice is all this?
Yellow dragon, describe your problem a bit better.
1. Does it do it all the time, or only hot, cold, or warm?
2. When it does start, does it idle roughly. Can you maintain idle without your foot on the gas?
3. Did it just start doing this all of a sudden?
4. Did you run out of gas lately?
5. When you get it started, and it stalls, do your lights or radio shut off also?
fs
Old Mar 10, 2005 | 04:28 PM
MestizoRacer310's Avatar
Default Re: '95 Accord 4cyl - starts but dies immediately (asianpoet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asianpoet &raquo;</TD></TR><TR><TD CLASS="quote">might also be your ignition switch..... Hey its possible, I HAD the same problem with my Integra... </TD></TR></TABLE>
That was my same problem w/ my '95 4cyl wagon. I got a new one installed and it runs/starts fine. Go replace it and you'll be all set.
KYRGYZ
Aug 17, 2017 09:14 AM
FrankDizzle978
Jun 21, 2014 12:05 PM
lilhatch89
Aug 11, 2010 04:44 AM
HONCORD
Feb 20, 2009 08:19 PM
