What need to attach fuel pressure meter to banjo bolt?
The banjo bolt on the fuel filter of my CRX has nut that can be removed to fit a pressure guage. I need to measure fuel pressure and want to know what to buy. Need info on both a guage and the fitting(s). Looking for mechanical. I wont put the guage in the cabin and prolly will remove the guage when Im done.
Thanks for any info.
OK.. thanks.. so the fitting on the guage fits the hole exposed in the top of the banjo bolt that is put there for measurement?
I almost bought the BM but I wasn't sure if I needed an extra fitting or two to make it work.
From: I told you to wait in the truck in Texas, United States
The B&M fuel gauge uses 1/8"-27 NPT..
It comes with a replacement bolt..
the size of the service bolt on the stock banjo bolt is 6mm x 1.0mm pitch.
the stock banjo bolt itself is 12mm x1.25mm pitch
jason_alt
Jul 8, 2005 03:12 PM
