Mysterious Oil Leak
Old Mar 7, 2005 | 12:40 PM
NaVamous's Avatar
Default Mysterious Oil Leak
A couple of months ago I hit something on the freeway, which caused damage to my shift rod, transmission, and CV joint. I had it all replaced, the day after I got my car back, I noticed an oil leak on my drive way. My drive way is an incline, and my car only leaks on incline. I took it back to the shop thinking it was the transmission seal but the shop determined that the transmission was fine. They told me that oil leak looks like engine oil. I checked my oil level, seemed normal before, just now I've noticed it has decreased. The shop told just to be sure, put a cardboard underneath the car to see where the oil is leaking from.
The leak is coming from between the engine block and the transmission, but the oil drips down to the front side of the tranny. What could possibly cause this leak?
Old Mar 7, 2005 | 01:07 PM
asubennett's Avatar
Default Re: Mysterious Oil Leak (NaVamous)
Ussually if it is on the front side of the tranny it is a cam seal or the VTEC solenoid.
But since it started after you hit something it could also be the oil pan??.. Clean it up real good, drive it briefly and then check.
Old Mar 7, 2005 | 01:58 PM
NaVamous's Avatar
Ok, I'll go ahead and follow what you suggested.
Old Mar 7, 2005 | 02:42 PM
Do_Ster's Avatar
yeah definitely check out your oil pan first. if not, then it might be your main seal.
Old Mar 7, 2005 | 10:55 PM
PrettyLude's Avatar
clean it up real good with carb cleaner and see where it drips
Old Mar 8, 2005 | 02:05 AM
2000Pimpinex's Avatar
Default Re: (PrettyLude)
I would say its coming from the main seal. I have the same problem after I got my tranny rebuilt.
diyguy13
Mar 12, 2009 05:55 AM
yuen
Nov 12, 2006 06:43 AM
92ehatch
Nov 10, 2005 02:16 PM
DAintegraGSR
Apr 28, 2005 08:22 PM
deepnite
Oct 9, 2002 01:46 PM
