Best camshafts for individual throttle bodies?
Old Mar 7, 2005 | 12:26 PM
whytTypeR's Avatar
Default best cams for indiviual throttle bodies anyone ?????
some people were saying skunk2 stage 2 not sure tho anyone else know??
Old Mar 7, 2005 | 12:28 PM
JDM_DC2_2001's Avatar
skunk2 is not that good.
Old Mar 7, 2005 | 12:40 PM
Philly_NBP_R's Avatar
Default Re: (JDM_DC2_2001)
Toda C's? Other's have also used Vtec Killers - but they're a little extreme....
Do a search, this has been covered many times.
Old Mar 7, 2005 | 01:08 PM
Big Phat R's Avatar
Default Re: best cams for indiviual throttle bodies anyone ????? (whytTypeR)
The biggest baddest lumpiest ones you can find.
Old Mar 7, 2005 | 01:10 PM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: best cams for indiviual throttle bodies anyone ????? (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">The biggest baddest lumpiest ones you can find.
who makes those again?
Old Mar 7, 2005 | 01:18 PM
Blind-Fashion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC2_2001 &raquo;</TD></TR><TR><TD CLASS="quote">skunk2 is not that good.</TD></TR></TABLE>
hmmm... The s2s2's have been tried and tried over and over with great results from many people.
to trial user
Old Mar 7, 2005 | 01:20 PM
whytTypeR's Avatar
Default Re: best cams for indiviual throttle bodies anyone ????? (LudeEFv2.0)
TWM Throttle Bodies 2000 Series ITB's (50mm) *without vacumm cannister
Old Mar 7, 2005 | 01:32 PM
whytTypeR's Avatar
ok this is what is done to my engine brand new unused short bottom end block form acura,i have 8.8lb act flywheel forum racing pulley set.jdm headers . know i want to buy the TWM Throttle Bodies 2000 Series ITB's (50mm) *without vacumm cannister but want to know what i should add so engine wont screw up i know i need to get a fuel management system like hondata but i dont know which one either HELP!!!!!
Old Mar 7, 2005 | 01:43 PM
chameleon's Avatar
Default Re: (Blind Fashion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind Fashion &raquo;</TD></TR><TR><TD CLASS="quote">
to trial user</TD></TR></TABLE>
any good cams made for the compression you have is what you need, itbs will help the cams flow great with the compression you will be working with but cams are not intended for itbs but for compression of your motor. so i recommend some skunk2 stg2s, bc3+s or toda Bs.
Old Mar 7, 2005 | 03:02 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whytTypeR &raquo;</TD></TR><TR><TD CLASS="quote">ok this is what is done to my engine brand new unused short bottom end block form acura,i have 8.8lb act flywheel forum racing pulley set.jdm headers . know i want to buy the TWM Throttle Bodies 2000 Series ITB's (50mm) *without vacumm cannister but want to know what i should add so engine wont screw up i know i need to get a fuel management system like hondata but i dont know which one either HELP!!!!!</TD></TR></TABLE>
It sounds like running ITB's will cause you more harm than good.
I'd stick with a stock ITR intake manifold, if I were you.
Old Mar 7, 2005 | 04:36 PM
GUILOTINE's Avatar
Kill Gil
Old Mar 7, 2005 | 05:02 PM
Dougie Pants's Avatar
Default Re: (GUILOTINE)
Import Review 8/10/03 Cams: Skunk Type 2 VS Toda Spec D AGAIN
http://www.importreview.com/re....html
Import Review 6/12/03 Skunk Type 2 and 3 VS Toda Spec D
I have a '96 Spec ITR w/ TWM ITB's and have had them on for 2 years now. I'll be running the S2S2 this year and I know I will have great results. I wish you the best of luck...
Old Mar 7, 2005 | 05:27 PM
92TypeR's Avatar
FSAE
If you do not have a fuel management setup figured out at this stage, I do not think you should be interested in what camshafts to run.
For stock compression, and 50mm ITB's, you can definately see an improvement using a moderately large cam. ITB's love to feed on as much air as they can get their hands on, so a cam with large primaries and large VTEC lobes would be ideal.
The new Skunk2 Pro-1 cams are a good choice. They have a very healthy midrange and top-end. They are stronger throughout the powerband compared to the BC 3's, and 3+'s. I would consider running these. What is even better, is that they will suit you well down the road if/when you up your compression.
As for fuel management, it is very possible to run Hondata. There are many people who use Hondata/Uberdata for their ITB's and have very driveable cars.
However, the problem with ITB's is that they do not create enough vacumn at anything above idle, so the MAP sensor has a hard time distinguishing what load the car is under. You really need an EMS style tuning software/hardware like AEM, MoTec, Haltec. Those EMS's will allow you to tune based off a combination of Throttle Position and MAP sensor.
The new Crome beta also has TPS tunability, and is free, but requires you to be mechanically/technically inclined to tune yourself. That is unless you find a local tuner that knows the Crome interface.
Good luck,
-Marshall-
Old Mar 7, 2005 | 05:33 PM
whytTypeR's Avatar
Default Re: (Dougie Pants)
so instead of the indiviual throttle bodies what else should i do to make my itr faster NO TURBO only str8 motor.
Old Mar 7, 2005 | 06:00 PM
92TypeR's Avatar
FSAE
Default Re: (whytTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whytTypeR &raquo;</TD></TR><TR><TD CLASS="quote">so instead of the indiviual throttle bodies what else should i do to make my itr faster NO TURBO only str8 motor.</TD></TR></TABLE>
Higher compression, larger cams, good tuning. That would be a good starting point.
If you crave more power after that, the option of sleeving a block to 2.0L is always there.
How much money you are willing to spend, and what kind of life the car will have (street, strip, track...etc) will all dictate what power you will want.
ITB's do help boast power, but bench flows have shown modified and aftermarket Plenum style Intake Manifolds can be close to, or even exede that of ITB's. I know the AIR Intake Manifold has very good flow characteristics. Also, Endyn has posted up flow charts of 45 and 50mm ITB flow charts, along with their modified Skunk2 Intake Manifold, and they were all within 1-2cfm of eachother (~.500 lift).
Most people use ITB's to improve engine response, which is often criticle for road courses, circuit racing, etc.
Old Mar 7, 2005 | 11:37 PM
#1151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>me too...
Old Mar 8, 2005 | 12:58 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whytTypeR &raquo;</TD></TR><TR><TD CLASS="quote">TWM Throttle Bodies 2000 Series ITB's (50mm) *without vacuum canister </TD></TR></TABLE>
You really need a vacuum canister, particularly if you plan on daily driving your car. Your brake booster requires vacuum, as well as your PCV system. You also need a stable vacuum signal to your FPR and MAP sensor. ITBs are not just plug and play; lots of tuning is required to make a car behave in a civilized manner with ITBs.
Old Mar 8, 2005 | 01:41 AM
sneakychaos's Avatar
Default Re: best cams for indiviual throttle bodies anyone ????? (b19coupe)
Toda C's.. but I'm bias because I used to have them and their for sale.
Old Mar 8, 2005 | 10:13 AM
revvin9k's Avatar
You're a tool. Have you had any experience with them personally? Thought so.
Have em in my car and I love em.
ekslammed
Nov 29, 2007 10:40 AM
nenny2 da9
Apr 9, 2007 07:56 PM
black99x
Jul 13, 2006 06:58 PM
westfire25
May 15, 2006 06:22 PM
civicd16ex
Oct 26, 2005 03:17 PM
