this crx
Old Mar 7, 2005 | 12:07 PM
h22_cx_hatch's Avatar
Default this crx
im a noob to the site and there is this problem with my new crx. the ad said it ran great, we started it up, i paid, got it a few days later, and now it sucks. im thinking the guy sabatoged it. the car is all stock. no mods. the motor wont start, but the spark plugs and stuff are fine. help me
Old Mar 7, 2005 | 12:19 PM
Del Sol SiR's Avatar
does it crank ?
Old Mar 7, 2005 | 12:24 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (DELSOLEMITE)
You'll need to explain yourself a little better, just saying "my car wont start" won't help us any.
First off, Check to see if you are getting spark and fuel.
Old Mar 7, 2005 | 12:29 PM
Default Re: (LSVTEC 91 Civic)
thank you for the lecture
yes there is crank and spark and i filled it up with 1/2 gallon of gas(for now)
Old Mar 7, 2005 | 01:28 PM
Default Re: (hndacrx2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hndacrx2 &raquo;</TD></TR><TR><TD CLASS="quote">thank you for the lecture
yes there is crank and spark and i filled it up with 1/2 gallon of gas(for now)</TD></TR></TABLE>
was it empty before?
Old Mar 7, 2005 | 01:45 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
a decent article about diagnosing a "no-start" situation
read all 3 pages :
http://autorepair.about.com/cs...a.htm
You you try to start it,does the check engine light stay on?
If so check fuse #14:
Old Mar 7, 2005 | 02:26 PM
89efstd's Avatar
just casue it wont start doesnt mean it was sabatoged, you have to go buy yourself an helms manual and run down the list of potenital problems ,just saying it it wont start and theres crank isnt that much info buy the book its like 10bucks
Old Mar 7, 2005 | 03:03 PM
Banned
Yes, but is the fuel getting to the engine?
Remember,
You need the following things for a car to run:
Spark
Fuel
Air
Compression
and... correct timing.
Could also be an electrical problem somewhere.
Old Mar 7, 2005 | 03:07 PM
4drEF's Avatar
Keyboard Humorist
Is the fuel pump whirrrrring when you turn the key to the ON position?
Common problem - bad main relay.
Old Mar 7, 2005 | 03:08 PM
Iceycrx's Avatar
This is like the guy who bought my old HF. Except it ran fine when I owned it. He didn't know how to drive stick and stalled it out like 10x, floored the gas when trying to start it and wondered why it wouldn't start.
No one was trying to lecture you but don't come here and complain and expect help and respond with a smartass comment because ppl cant understand your problem due to the fact you didnt give enough information.
Anyways.....
It turns over, but doesn't startup I think is what you said.
check each plug wire and then each spark plug.
Then make sure you got more then 1/2 gal of gas in the tank total.
Make sure there is no check engine light.
Make sure your getting fuel in the cylinders
Old Mar 7, 2005 | 03:30 PM
Default Re: (Iceycrx)
i finally fixed it. the problem was electrical wires. i dont know which wire, but it seemed to be chewed up by a rat. i called the guy up, and said the garage he stored it in had dozens of rats. ...................
Newbster91
Oct 7, 2014 10:52 PM
GreenGoblinEF
17
Feb 28, 2010 03:00 PM
khoalizzle
Sep 10, 2008 10:51 AM
TheSiWay
Jun 21, 2008 07:21 PM
about:blank
12
Jan 19, 2008 02:13 AM
