Hondata problem help??!?!B18
Old Mar 7, 2005 | 11:31 AM
krystianitr's Avatar
Default Hondata problem help??!? !B18 Code 22!!
Hi,I have bought Hondata obd1,conversion harness obd1 to obd2, s100 hondata and chip for set up CR 12.3 cam shafts stage 2 ,RC 310CC I put everything into my car Honda integra type R EDM!!!!not US. After I started my engine there was check error 22 .Please help me .
Modified by krystianitr at 8:38 AM 3/8/2005
Old Mar 8, 2005 | 07:38 AM
Default Re: Hondata problem help??!? !B18 Code 22!! (krystianitr)
I need help
Old Mar 8, 2005 | 07:48 AM
NJIN BUILDR's Avatar
You may have better results at the Hondata forum.Lots of Hondata specific information. http://www.hondata.com
Glenn
Old Mar 8, 2005 | 08:50 AM
Default Re: Hondata problem help??!? !B18 Code 22!! (NJIN BUILDR)
I have code 22 Vtec oil pressure switch.I have ITR EDM
and my ECU The P06 ECU is from a 1992-1995 Honda Civic CX. That ECU has been converted
to P28 Spec with the addition of the VTEC transistor.
And I dont know how I have eliminate code 22 Vtec oil pressure switch?
Help me
Old Mar 8, 2005 | 09:52 AM
moto1320's Avatar
If the EDM is like the JDM then you do not have a vtec oil pressure switch but that ECU is looking for it. You can splice voltage into the wire for this circuit if that is the case or use the correct plate including the sensor, or tap the plate that you have and install the sensor.
slammedNslowLS
Engine Management and Tuning
May 11, 2010 06:50 AM
krystianitr
Mar 1, 2005 12:08 PM
DLB1994
Mar 20, 2003 04:05 PM
Backmarker
Aug 30, 2002 09:22 AM
Backmarker
Aug 29, 2002 10:03 AM
