fuel pressure
I just upgraded my head and cams, and i see that im running lean. The thing i was trying to figure out was what fuel psi does the b16a require? and also how do you test to see what your fuel psi is?
You can hook the fuel pressure guage into the service port at the fuel filter. There is a little bolt that goes in the top of the banjo bolt. If you remove this a guage can be put in its place. To adjust the pressure you will need an aftermarket regulator since the stock ones are none adjustable.
Ok there is a lock nut on the top of the regulator. Loosen it. There is a also an allen wrench type socket in the top of the stud sticking out of the regulator. After loosening the lock nut you use the allen key to adjust the pressure. I believe turning it to the right ups the pressure and turning left lowers it. Don't quote me on that.
You should use a guage while you're doing this so you know what you are setting it at and if you are turning it the correct way. Good Luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic »</TD></TR><TR><TD CLASS="quote">Ok there is a lock nut on the top of the regulator. Loosen it. There is a also an allen wrench type socket in the top of the stud sticking out of the regulator. After loosening the lock nut you use the allen key to adjust the pressure. I believe turning it to the right ups the pressure and turning left lowers it. Don't quote me on that.
You should use a guage while you're doing this so you know what you are setting it at and if you are turning it the correct way. Good Luck</TD></TR></TABLE>
Disconnect the vacuum hose from the fpr. A 3/8" nutdriver loosens the bolt. Use a 9/64" allen wrench to adjust. You're right! cw to increase pressure, ccw to lower.
Replace the vacuum hose.
You should use a guage while you're doing this so you know what you are setting it at and if you are turning it the correct way. Good Luck</TD></TR></TABLE>Disconnect the vacuum hose from the fpr. A 3/8" nutdriver loosens the bolt. Use a 9/64" allen wrench to adjust. You're right! cw to increase pressure, ccw to lower.
danno33
Dec 27, 2006 02:16 PM
Ignitecivic
Feb 6, 2002 08:24 PM
