Suspension & Brakes Theory, alignment, spring rates....
for all who have installed Omniman coilovers LOOK!!
Old Mar 7, 2005 | 05:33 AM
vtekthis's Avatar
Default for all who have installed Omniman coilovers LOOK!!
my buddy just installed his omniman coilovers (street setup on his 93 hatch) and the front seems to bounce alot. does anyone know how to set a initial on the setup? like how many turns in on the bottom fork in the front? or just a setup that has worked good for ur setup?
thanks Darren
Old Mar 7, 2005 | 11:54 AM
whiteJDMdc2's Avatar
Default Re: for all who have installed Omniman coilovers LOOK!! (vtekthis)
just out of cuiosity did you guys pre-load the springs before the install..... if you didnt this my be the problem
Old Mar 7, 2005 | 01:40 PM
slammed_93_hatch's Avatar
Default Re: for all who have installed Omniman coilovers LOOK!! (JdmB18C1dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmB18C1dc2 &raquo;</TD></TR><TR><TD CLASS="quote">just out of cuiosity did you guys pre-load the springs before the install..... if you didnt this my be the problem</TD></TR></TABLE>
why? it doesn't do anything
Old Mar 7, 2005 | 02:01 PM
Default Re: for all who have installed Omniman coilovers LOOK!! (slammed_93_hatch)
the pre load is supposed to help a lil with the daily driven aspect of the coilovers.... im just going off what my set of omnipower full coils said to do when i installed and i have had no prolems
Old Mar 7, 2005 | 02:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmB18C1dc2 &raquo;</TD></TR><TR><TD CLASS="quote">the pre load is supposed to help a lil with the daily driven aspect of the coilovers.... im just going off what my set of omnipower full coils said to do when i installed and i have had no prolems</TD></TR></TABLE>
when you have the car setting on all four wheels the pre-load does NOTHING, in fact it is nullafied
Old Mar 7, 2005 | 02:34 PM
PIC Performance's Avatar
Due to whatever reason, there might've been a large gap between the spring perch and the upper mount allowing for some play in the spring. Correct preloading would take care of that.
Old Mar 7, 2005 | 02:50 PM
.water's Avatar
Default Re: for all who have installed Omniman coilovers LOOK!! (Noob4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noob4life &raquo;</TD></TR><TR><TD CLASS="quote">Due to whatever reason, there might've been a large gap between the spring perch and the upper mount allowing for some play in the spring. Correct preloading would take care of that. </TD></TR></TABLE>
ya ..that should do it..other than that..u guys installed wrong.lol
btw: preload before put it in the car? the spring might fly off isnt it?
Old Mar 7, 2005 | 03:00 PM
Default Re: for all who have installed Omniman coilovers LOOK!! (Chris DC2)
Preload doesn't involve moving the tophat at all. Also the spring would not come from the factory compressed at all. Typically the spring perch and its lock are screwed upwards so that the spring isn't totally bouncing up and down, but its not very tight at all, which is where preload comes in. Preload is a very minute adjustment, we're talking about 5mm more or less.
Old Mar 7, 2005 | 05:45 PM
mike-y's Avatar
preload *might* be necessary if the spring compresses too much under the car's weight and causes a lack of shock travel and you might be hitting the bumpstops. if you preload, and then use the bottom collar to lower the car, you *might* be able to gain some shock travel, depending on how the coilovers are designed.
Old Mar 8, 2005 | 08:19 AM
vtekthis's Avatar
that was the problem!! preloading the springs fixed the bounce. And yes without the preload the spring did have a large gap to the tophat
thanks for the help
Old Mar 8, 2005 | 04:07 PM
Oooh a fellow Long Islander! Enjoying the snow?
Old Mar 8, 2005 | 05:14 PM
glad I could help a bit with your problem.... contrary to what some people may think it is a good thing to pre-load the springs out of the car before install... like was stated it ensures there is no gap between spring and the top hat and allows for full travel of the shock.... enjoy those coils I will be installing mine this friday cant wait
Old Mar 9, 2005 | 08:36 AM
vtekthis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noob4life &raquo;</TD></TR><TR><TD CLASS="quote">Oooh a fellow Long Islander! Enjoying the snow?</TD></TR></TABLE>
yeah cause i took off from work, my hatch, see sig, gets upset in the snow
k_lude
Mar 8, 2007 11:52 PM
HondaEF
Oct 2, 2006 03:16 PM
hatch_dude
10
Jul 8, 2006 10:00 PM
pucancakes
29
Jul 2, 2006 04:24 AM
Lifter2012
Feb 16, 2006 07:11 AM
