Will these parts fit without custom fabrications?
Old Mar 7, 2005 | 03:06 AM
X12's Avatar
X12
Default Will these parts fit without custom fabrications?
Hey,
I have a few questions about some parts that I have found on PasswordJDM and PhaseNine online stores. Would the EK CTR manual gauge cluster fit into a 97 EK Hatch and would there be appropriate wiring for it? Most of these parts are labeled as EK CTR, such as the spoiler, front bumper and lip, rear bumper and lip, headlights, and taillights from password. However, without fabrications, does it mean those items would only bolt on correctly to a 99-2000 EK hatch? Here's the link to the site with the items. http://www.passwordjdm.com/aboutPassword.htm
It's about halfway down where all the listings say EK CTR. Thanks a bunch.
-Andrew
Old Mar 7, 2005 | 03:08 AM
soundbomber's Avatar
Default Re: Will these parts fit without custom fabrications? (X12)
you need to do a 99-00 civic front end conversion for all those ctr parts to work...the wing/mirrors/etc are bolt on. the manual gauge cluster is plug and play
Old Mar 7, 2005 | 03:35 AM
ecahatch's Avatar
Senor Miembro
Default Re: Will these parts fit without custom fabrications? (soundbomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">you need to do a 99-00 civic front end conversion for all those ctr parts to work...the wing/mirrors/etc are bolt on. the manual gauge cluster is plug and play</TD></TR></TABLE>
if you had a 99-00 civic hatch all those exterior parts you asked will work w/o modification
Old Mar 7, 2005 | 07:27 AM
X12's Avatar
X12
Thanks. So the exterior parts would need custom fabrication and the manual cluster from the CTR would just fit right into mines and the wiring would be perfect?
-X12
Old Mar 7, 2005 | 08:20 AM
ek four's Avatar
Default Re: (X12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X12 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks. So the exterior parts would need custom fabrication and the manual cluster from the CTR would just fit right into mines and the wiring would be perfect? </TD></TR></TABLE>
NO custom fabrication needed.. everything bolts up. u just need EVERYTHING off the 99-00. vice versa.
YES, the ctr cluster would just plug right up. (any/all 96-00 civic clusters plug right up)
JERKSiRcoupe
Aug 25, 2015 05:14 PM
sickEK4
Sep 10, 2009 06:59 AM
crazyimport
Oct 18, 2004 12:15 PM
Buktheng
13
Oct 7, 2004 01:18 PM
hatchii
Apr 8, 2004 09:15 PM
