Honda Engine help
Old Mar 6, 2005 | 10:49 PM
91hatchnewb's Avatar
Default Honda Engine help
Ok, my little commuter 1991 honda civic was in an accident and I need to replace a lot of the front of the car. So, while I'm busy fixing this damn thing up b/c I thought it would be fun, I am going to swap a new motor in for the old 170k mile one. Well, I don't need anything fast or anything but almost every motor I see is JDM, so I was wondering, if I bought a cheap little JDM motor for $300 or whatever, would it be able to pass smog? I know practically any motor will swap but idk if JDM motors would be able to pass. Anyone know?
P.S. Don't tell me that I should swap a B16 and turbo it or anything like that. This is my beater and I just want it to get groceries and save gas. Not to start a flame war but I already have a 2000 Mustang GT and it runs mid 13's so it's good enough for me.
Thanks,
Roy.
Old Mar 6, 2005 | 10:51 PM
Default Re: Honda Engine help (91hatchnewb)
Oh yeah, it's a DX with the D15B2 but I'm sure most of you knew that. Oh, and I'm only looking to spend maybe $400 max on the engine. And tranny if I need one to go with the new motor, or can I use my DX one? It needs a new clutch anyway, damn tranny won't hold a gear for the life of it.
Old Mar 6, 2005 | 10:56 PM
Exempt's Avatar
Easiest, cheapest swap for it, would be a USDM Si engine (D16A6)... I know youd have to wire from DPFI to MPFI, not sure what else tho... That may be it...
Old Mar 6, 2005 | 10:57 PM
Default Re: (Exempt)
Ok, so how do you wire from Dual point to Multi point? Also, where could I find a D16A6? There's only one on Ebay right now and the guy seems kinda sketchy.
Old Mar 6, 2005 | 10:58 PM
Default Re: (91hatchnewb)
I would keep the same motor I have now but the damn thing leaks oil from the head and the spark plugs are always oil fouled. I don't know what's wrong with it but I don't want to spend money to find out and fix it when I could just be cheap and buy a different motor.
Old Mar 6, 2005 | 10:59 PM
Exempt's Avatar
The FAQs thread has a few links on the subject... For any swap youd have to do that anyways...
FAQ thread:
https://honda-tech.com/zerothread?id=637661
As for where to get it, you can probably find one locally... Best bet is to find someone whos swapping for another engine...
SilverCivic97
May 3, 2010 04:39 PM
CivicSiRacer
May 24, 2007 12:36 PM
88crxsir
Aug 8, 2004 02:58 PM
