Can someone run a VIN for me? please possible stolen R!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^CX_d16 »</TD></TR><TR><TD CLASS="quote">run that VIN and tell me if its clean
What's the story?
</TD></TR></TABLE>What's the story?
just browsing HT and saw someone doing a b18c5 swap and the VIN was right there close up on the tranny. just kinda weary of c5 swaps, where did that b18c5 come from?
"so if you see a hatchback with a type r motor,
most likely it was your type r's old motor"
-Type Wah
-Type Wah
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando »</TD></TR><TR><TD CLASS="quote">I thought that the engine vin doesn't coinside with the vin located on the dash? I guess regardless if you can find out if it's good or not...no worries then.</TD></TR></TABLE>
The engine serial number (right below the engine code) doesn't coincide with the VIN, however there is a VIN plate both on the front of the tranny, and at the bottom front of the engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon »</TD></TR><TR><TD CLASS="quote">legit man... motor was just bought from a salvage yard</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">
The engine serial number (right below the engine code) doesn't coincide with the VIN, however there is a VIN plate both on the front of the tranny, and at the bottom front of the engine.</TD></TR></TABLE>
This is not true. If you go to an Acura dealer and ask them to run your VIN they will be able to tell you the blocks serial number.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00PYDC2R »</TD></TR><TR><TD CLASS="quote">
This is not true. If you go to an Acura dealer and ask them to run your VIN they will be able to tell you the blocks serial number.</TD></TR></TABLE>
Yes, both are recorded. They have nothing to do with each other though. For example, the block number is recorded to the VIN, however you can not do a lookup from the block number itself. They don't share a sequence number or anything else, it's just a field that's filled out in the VIN's history record.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^CX_d16 »</TD></TR><TR><TD CLASS="quote">just browsing HT and saw someone doing a b18c5 swap and the VIN was right there close up on the tranny. just kinda weary of c5 swaps, where did that b18c5 come from?</TD></TR></TABLE>
WTF?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
-Type Wah</TD></TR></TABLE>
You know that quote has been thrown around here for years, I never thought people would actually take it seriously and run VIN's on every engine they find outside the R forum
WTF?
Lookincrazy
32
Jul 19, 2002 07:36 AM
