How To: Install Datalogging cable to your OBDI ecu
Old Mar 6, 2005 | 07:57 PM
JDMlyfestyle's Avatar
Default How To: Install Datalogging cable to your OBDI ecu
Found this Kick *** write up a few days ago so i thought i would share it. I forget who wrote it. But if the person who wrote this see's this post I am not taking any credit for it.
How To Make Nokia Data logging Cable
These directions are pretty much the same as Jim Truett’s (Thanks Jim). His instructions were good but a little confusing to me. So here is my write up.
So first off I’ll assume you have an ODBI ECU with the CN2 de-soldered.
Next you need the USB cable Part #170-0787 from Radio Shack. I got mine there today 6/25/2004 for $9.95.
Once you have that cable you will need to cut off the cell adapter part on the end. Then you will strip the cable to expose the wires. Strip off about 1 inch.
Once you stripped the shielding you will see the shield conductor (silver wires in a woven pattern shielding the other wires). Twist this shielding to make it into a single wire. There will be some type of aluminum foil surround all the wires now, remove this foil.
Next you will strip the brown wire and solder it to the shielding conductor that you twisted into a single wire. It should look like this.
Then you will strip the orange and red wires. Then drill a hole in the side of the ECU case and feed the wire through.
I used some random wires lying around to solder to the CN2 points. This was because the USB cable wires were too thin and the one was to thick to make a good solder connection.
Then you will solder the brown/shield conductor to #1 pin on CN2
Solder the orange wire to #2 pin on CN2
Solder the red wire to #4 pin on CN2
As you can see I wrapped it around the ECU bar. This was done to help avoid accidentally pulling on the black wire and having to re-solder everything. This way then you pull on the wire it seems to put the pressure on the bar and not the solder point on CN2. Or you can use a zip tie.
Then of course wrap those connections with eletrical tape or use shrink wrap.
Here is the end result.
Also make sure you download the USB drivers from here:
http://www.pgmfi.org/twiki/bin...Tools
Old Mar 6, 2005 | 08:10 PM
Luserkid's Avatar
Default Re: How To: Install Datalogging cable to your OBDI ecu (JDMlyfestyle)
Hmm.... seems really interesting. And just by doing that you could log your data without Hondata, or Uberdata?
Old Mar 6, 2005 | 08:12 PM
you would have to have a datalogging program yes.
http://www.ecucontrol.com is what im gonna try if not then i will be using Uberdata/crome.
Old Mar 6, 2005 | 08:16 PM
FERIOkid's Avatar
super duper
Old Mar 6, 2005 | 08:18 PM
Turbogixxer's Avatar
Default Re: (JDMlyfestyle)
j000 need to go to the uberdata forums and pgmfi.org more!
Old Mar 6, 2005 | 08:43 PM
litterbox's Avatar
I am a (Trial User) Army
Holy Cow!
Help me out, is "loggin your data" simply recording the a/f, timing settings at specific rpms? So then the point of this would be to see how your engine is running, then use that info to tune accordingly with uber/hondata?
Old Mar 6, 2005 | 08:48 PM
Soccerking3000's Avatar
Default Re: How To: Install Datalogging cable to your OBDI ecu (litterbox)
i use that exact setup with uberdata, you can log a/f ratio, speed, rpm, ait, coolant temp, and tps. It also can record exact a/f ratios per rpm in a lambda log. It makes it sooo easy to tune. gets a BIGGGGG from me, ohh and they are working on a new part of uberdata which saves the lambda log then auto corrects the fuel tables to a/f ratios you put in. So like if you want your air to fuel to be 12:1 from 0psi-12psi you just plug in that value and it autocorrects the values. It will make tuning unbelievably easy, like 20 minutes easy
Old Mar 6, 2005 | 09:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Help me out, is "loggin your data" simply recording the a/f, timing settings at specific rpms?</TD></TR></TABLE>
You use rpm and Map (engine load) to right cell(s) to mod. Say you have 11.5a/f at 5000 RPM and 0.35 in/hg (Mercury). You want 12.0a/f, you go to that cell and take fuel out to make it closer to 12a/f.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">ohh and they are working on a new part of uberdata which saves the lambda log then auto corrects the fuel tables to a/f ratios you put in. So like if you want your air to fuel to be 12:1 from 0psi-12psi you just plug in that value and it autocorrects the values. It will make tuning unbelievably easy, like 20 minutes easy </TD></TR></TABLE>
Yes, it is called auto tune. You can hit your a/f easier will it. Remember, A/f is only half of tuning. Anyone can add and subtract to get a a/f.
Old Mar 6, 2005 | 09:14 PM
Technically A/F is 1/3 of tuning..lol
A/F
Ignition
Cam Timing
I just signed up in the Uberdata forums this weekend. Ive got alot of stuff going on but once i start playing around with the ECU more and all the settings ill be in there
thrty8street's Avatar
Default Re: How To: Install Datalogging cable to your OBDI ecu (turbogixxer)
nice
Old Mar 6, 2005 | 09:15 PM
ya but that is a simple way to put it for beginners, and the easiest way to make sure the car wont detonate under boost, we all know what happens when you lean out while boosting...
Old Mar 6, 2005 | 09:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Technically A/F is 1/3 of tuning..lol
A/F
Ignition
Cam Timing</TD></TR></TABLE>
Some cars do not have adj. cam gears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">ya but that is a simple way to put it for beginners, and the easiest way to make sure the car wont detonate under boost, we all know what happens when you lean out while boosting...</TD></TR></TABLE>
You can have knock (detonation) with rich a/f. Like I said, a/f is not everything. More data you have, the better your tune will be.
Old Mar 6, 2005 | 09:51 PM
Default Re: (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
Well if you spend Thousands of dollars to get a Bad *** motor. and do not get adjustable cam gears i poo on those people. a $250 max investment on some cam gears could easily net them 15 whp on the right setup. 15whp on $250 or less is awesome
Old Mar 6, 2005 | 09:59 PM
Well if you spend Thousands of dollars to get a Bad *** motor. and do not get adjustable cam gears i poo on those people. a $250 max investment on some cam gears could easily net them 15 whp on the right setup. 15whp on $250 or less is awesome </TD></TR></TABLE>
Your missing the point. I am speaking in general. Cam and igntion are still timing, no matter what way you slice it. Different engine set-ups (NA, FI) will react in different ways to the same changes on both motors.
Old Mar 6, 2005 | 10:01 PM
Your missing the point. I am speaking in general. Cam and igntion are still timing, no matter what way you slice it. Different engine set-ups (NA, FI) will react in different ways to the same changes on both motors. </TD></TR></TABLE>
Im not missing the point. Just being difficult tonight
B16aDasher's Avatar
awsome add it to the faqs
Old Mar 6, 2005 | 11:10 PM
duh blacksheep's Avatar
Default Re: (B16aDasher)
would this mean its logging the already a/f ratio from the already inaccurate stock 02 sensor?
Old Mar 6, 2005 | 11:14 PM
no you need to install a wideband o2 in its place. then review the logs and tune the motor to your satisfaction then you can replace the wideband with the stocker.
Old Apr 3, 2005 | 08:08 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
save
Old Apr 11, 2005 | 11:53 PM
bry-typeR's Avatar
hmmm???i have a 0BD2.just wondering if i can do it also on my 0DB2 ecu?
Old Apr 12, 2005 | 02:00 AM
Frozen E's Avatar
H-T White Ops
Default Re: How To: Install Datalogging cable to your OBDI ecu (bry-typeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bry-typeR &raquo;</TD></TR><TR><TD CLASS="quote">hmmm???i have a 0BD2.just wondering if i can do it also on my 0DB2 ecu?</TD></TR></TABLE>
No
Old Apr 12, 2005 | 05:47 AM
Extreme's Avatar
You don't have to, OBD2 is capable of datalogging by design.
You will need a OBDII reader/datalogger.
Old Apr 12, 2005 | 09:45 AM
bry-typeR's Avatar
Default Re: How To: Install Datalogging cable to your OBDI ecu (Extreme)
oh thank u to the advise.actuly i having a problem to my car.can u tell me what is the meaning of this code P0500 n there any idea i can solve the problem.the paper clip can help.
Old Apr 12, 2005 | 11:08 AM
NatedoggAZ's Avatar
do you know how to wire up a serial cable insteal of that USB cable?
Old Apr 12, 2005 | 07:31 PM
Extreme's Avatar
that would be VSS Circuit Malfunction (M/T) aka vehicle speed sensor.
