help on replacing rotors on 96 Accord
help on replacing rotors on 96 Accord . i got the pads and calipers off, now i am stuck on uninstalling/take off the rotor, i tried taking off the hub nut, and still will not come off! am i miss something here, i dont know what to do from here, please help
if ya can teach me with directions, it would help, thank you!
well, the rotors are pressed on...either you can take the entire hub assembly off and take it to a machine shop, or figure out a way to pry them off...but the new rotors need to be pressed in as well, so i'd just take off the entire hub if i were you...
I had to replace my rotors on my 95. All you have to do is put the rotor in a vise and put something that will fit around the hub without messing with the bearings and beat the hell out of it. If you do it right it won't mess up the bearings. The local brake shop wanted $80 to press the hub. Took me about 3 min. at school.
