JDM s20 tranny on a USDM z6?
Old Mar 6, 2005 | 07:22 PM
JDM-EJ1's Avatar
Default JDM s20 tranny on a USDM z6?
My automatic tranny on my d16z6 recently went out, so I am planning to do a tranny conversion, there is a local junkyard that has a JDM d series s20 tranny for cheap, I'm wondering if this tranny will bolt on to my USDM d16z6 and work without any problems. Thanks.
Old Mar 6, 2005 | 07:23 PM
Kyles ej1's Avatar
Default Re: JDM s20 tranny on a USDM z6? (JDM-EJ1)
yes it will work
Old Mar 6, 2005 | 07:28 PM
JDM-EJ1's Avatar
Default Re: JDM s20 tranny on a USDM z6? (93blkej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93blkej1 &raquo;</TD></TR><TR><TD CLASS="quote">yes it will work</TD></TR></TABLE>
Awesome, thanks man.
Old Apr 2, 2005 | 10:51 PM
Redline96LX's Avatar
* B A N N E D *
bump for a conformation. sorry im sure the answer is here, but theres sublte differences. can you take this S20 LSD tranny and use on ANY 92-00 d series? I wonder if i can put it on my 96 D16Y7 and use the D16Y8 tranny forks as there stronger, being steel.
Old Apr 2, 2005 | 11:14 PM
Bond's Avatar
Default Re: JDM s20 tranny on a USDM z6? (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">bump for a conformation. sorry im sure the answer is here, but theres sublte differences. can you take this S20 LSD tranny and use on ANY 92-00 d series? I wonder if i can put it on my 96 D16Y7 and use the D16Y8 tranny forks as there stronger, being steel.</TD></TR></TABLE>
Yes they are stronger but unless your pushing 300hp you'll never have to worry about breaking a fork. For most applications the aluminum will be just fine and you shouldn't have any problem. You can only shift so fast and if you shift right you shouldn't be able to break anything. But if you can get your hands on one then throw it in.
Old Apr 3, 2005 | 12:18 AM
95singlecamvtec's Avatar
I have a S20 on my z6, it bolted up perfectly with no problems.
Old Apr 3, 2005 | 12:25 AM
Bond's Avatar
Default Re: JDM s20 tranny on a USDM z6? (95singlecamvtec)
Yeah, I got a s20 from an Si waiting to be installed. Also waiting on Exedy clutch too.
Old Apr 3, 2005 | 11:04 AM
Do_Ster's Avatar
to answer the first part of question, yes all d-series trannies can be used with all d-series motors from, not sure about the new D17 though.
Old Apr 3, 2005 | 11:09 AM
JDM-EJ1's Avatar
Default Re: JDM s20 tranny on a USDM z6? (_OEM_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _OEM_ &raquo;</TD></TR><TR><TD CLASS="quote">
to answer the first part of question, yes all d-series trannies can be used with all d-series motors from, not sure about the new D17 though.</TD></TR></TABLE>
That's good to know, thanks everyone!
Anti_AM_
Jan 10, 2009 10:31 PM
slor209
Jan 14, 2007 11:04 PM
im done
Nov 22, 2004 07:28 PM
coot_er
Oct 8, 2004 08:54 AM
LorenGeist
17
Aug 13, 2004 11:52 AM
