Body Molding Questions - Difficult to replace?
Old Mar 6, 2005 | 07:21 PM
Quik89Si's Avatar
Default Body Molding Questions - Difficult to replace?
I'm about to buy some new OEM body molding. You know, the piece that goes in the middle of the door to protect from door dings. How hard is this piece to remove and replace? Any advice is appreciated - thanks!
Alex
Old Mar 6, 2005 | 07:23 PM
doublethink's Avatar
Default Re: Body Molding Questions - Difficult to replace? (Quik89Si)
you do it from inside the door. you have to remove the interior panels and whatnot to get at it.
DONT just pull from the outside
where are you buying the new oem stuff from, how much? (if you dont mine me asking)
Old Mar 6, 2005 | 08:11 PM
Quik89Si's Avatar
Default Re: Body Molding Questions - Difficult to replace? (doublethink)
Gonna try and get the moldings from http://www.slhondaparts.com - here's hoping they come with clips! How hard is it to get to the clips and stuff from inside the door? I have heard some people have trouble breaking them.
Alex
Old Mar 6, 2005 | 08:38 PM
bucketheadCRX's Avatar
good luck with this and take pics if you can..ive been wanting to replace mine as well, but have been too much of a slacker and..quite frankly.. was afraid to ask how to do it without breaking ****(clips,etc)
Old Mar 6, 2005 | 08:40 PM
Exempt's Avatar
Are they just faded?
Try this:
http://faq.ef-honda.com/index....ng=en
Old Mar 6, 2005 | 09:31 PM
Quik89Si's Avatar
Default Re: (Exempt)
No, the fading isn't the problem - they look like they have "dents" or "creases" in them - each one has at least one or two of them, and it's just the big ones on the doors. If they were faded, I have some trim paint I could use, but there isn't much I can do about the wrinkles or whatever they are...
Has anyone actually taken theirs off and replaced them w/new ones? Give me some insight! Thanks!
Alex
Old Mar 6, 2005 | 11:09 PM
31flavorscivic's Avatar
Default Re: (Quik89Si)
I just yanked some off of a parts car tonite. The car was totally stripped, and I didn't do the door part yet, but I did do the part which is below the rear window. I had to use some needlenose pliers to get in the small space for one of the clips (you'll see what I mean when you go to do it. Even though you can barely see it, just clamping on it with the pliers should set it loose from the car. The other 2 clips are very easy to get out). Then you just slide the new ones in.
Old Mar 7, 2005 | 05:36 AM
Quik89Si's Avatar
Default Re: (31flavorscivic)
Are the clips an integral part of the molding, or are they replaceable on their own? Sounds like they should be replaceable.
Thanks for the info - hopefully the door portion is the same!
Alex
Old Mar 7, 2005 | 01:01 PM
*steps out from desk at work and walks to car*
yea, the clips are replaceable. They slide right out from a notch in the molding.
Old Mar 7, 2005 | 01:47 PM
tolnep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik89Si &raquo;</TD></TR><TR><TD CLASS="quote">Gonna try and get the moldings from http://www.slhondaparts.com - here's hoping they come with clips! How hard is it to get to the clips and stuff from inside the door? I have heard some people have trouble breaking them.
Alex</TD></TR></TABLE>
as info. one thing I have considered is a restoral of my CRX. I took some time and Id' every trim piece on the car.. and came up with something like 1000$ using the two online OEM honda parts sellers sl and majestic I think...
Old Mar 7, 2005 | 02:02 PM
HOND PWR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik89Si &raquo;</TD></TR><TR><TD CLASS="quote">Are the clips an integral part of the molding, or are they replaceable on their own? Sounds like they should be replaceable.
Your new mouldings will come with clips. They are easy to remove if you plan on replacing them...just pull them off
Old Mar 7, 2005 | 03:59 PM
Mr_CRX's Avatar
Default Re: (HOND PWR)
It's really not that hard, guys. Follow the directions
Old Mar 7, 2005 | 04:16 PM
Default Re: (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">It's really not that hard, guys. Follow the directions </TD></TR></TABLE>
ask h-t and ye shall recieve(sometimes) thank you sir
alex1321
12
Jan 25, 2013 08:59 PM
eL
Honda Fit
12
Dec 16, 2007 06:09 AM
K24_Y61P
Honda Civic (2001 - 2005)
33
May 18, 2007 09:12 PM
-BlueGSR-
Dec 15, 2002 06:41 PM
JunkeeCrx
Jun 25, 2002 12:07 PM
