Suspension & Brakes Theory, alignment, spring rates....
Questions on Sway bar's.
Old Mar 6, 2005 | 07:08 PM
ek9800's Avatar
Default Questions on Sway bar's.
I was wondering what sway bar would be best for my 98 hatch. I also heard that some sway bar's might have problems clearing my RS*R Ex-Mag exhaust?!?. Also i was wondering what would be the best mm? Thanks in advance
Old Mar 6, 2005 | 11:54 PM
ek9800's Avatar
Default Re: Questions on Sway bar's. (ek9800)
anyone?
Old Mar 7, 2005 | 01:40 AM
slammed_93_hatch's Avatar
the reason why no one asnwered your question was that, well you really didn't give us a question, you never told us what the car is used for what you want out of it, what other performance mods you have done or anything.
there is a thread in here that needs to be stickyed, basiclly it tells you how to ask a question
Old Mar 7, 2005 | 01:51 AM
ek9800's Avatar
Default Re: Questions on Sway bar's. (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">the reason why no one asnwered your question was that, well you really didn't give us a question, you never told us what the car is used for what you want out of it, what other performance mods you have done or anything.
there is a thread in here that needs to be stickyed, basiclly it tells you how to ask a question</TD></TR></TABLE>
Well, my question is what sway bar willl beneifit me the most for like, backroad's and curvey roads.
Old Mar 7, 2005 | 01:53 AM
SOHC4life 96's Avatar
So far my 99-00 Si sway bar has served me well. I'm sure I'll want to move on to bigger and better things eventually but we'll see. I say a GSR rear swaybar will do you good. I suggest you look into a subframe reinforcement though. 6th gens are known for subframes ripping.
Old Mar 7, 2005 | 05:49 AM
bbarbulo's Avatar
I had a 00 Si bar on mine, now I have a 22 mm ITR bar w/ Beaks. It's a 98 Civic fo doo.
The ITR bar has got to be the best thing I've ever done for so lil money. But now I gotta shell out $180 for the a-spec racing brace, but that's cool... totally worth every penny, esp given the rest of my susp!
I don't know a thing about clearance though cuz I don't have such problems.
Old Mar 7, 2005 | 10:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9800 &raquo;</TD></TR><TR><TD CLASS="quote">
Well, my question is what sway bar willl beneifit me the most for like, backroad's and curvey roads.</TD></TR></TABLE>
reading owns you, that still doesn't tell us much
Old Mar 7, 2005 | 01:44 PM
n1ek's Avatar
does your RS*R go over or under the rear lower control arm?
And 22mm is arguably the best to balance out a car that will see mostly street use.
Old Mar 7, 2005 | 04:48 PM
Jaesung's Avatar
Default Re: (bbarbulo)
i am planning on switching to a-spec as well. taking out the beaks.
go with a-spec. good stuff.
Old Mar 8, 2005 | 08:53 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: Questions on Sway bar's. (n1ek)
im a planning on getting the srr sway/tie bar kit. i just order a N1 muffler. i want my muffler put on with a big slant (jdm) when my question is the muffler going to hit/ or cause conflict with my swap bar? or should i get the bar first and have the muffler place work around it
Old Jun 1, 2005 | 12:44 AM
Jaesung's Avatar
Default Re: Questions on Sway bar's. (BLUE EH3)
only way to find out is to put it on your car and see it from under the car while it's on the lift.
you could ask the company but depending on your exhaust setup.
my 22mm itr sway bar cleared hi tech exhaust by like one inch. just barely enough. i highly doubt i could put 32mm hollow a-spec sway bar.
Old Jun 4, 2005 | 10:45 AM
Resident Evo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9800 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering what sway bar would be best for my 98 hatch. I also heard that some sway bar's might have problems clearing my RS*R Ex-Mag exhaust?!?. Also i was wondering what would be the best mm? Thanks in advance </TD></TR></TABLE>
Comptech 22m adjustable swaybar/tie-bar with endlinks
Old Jun 4, 2005 | 10:03 PM
jboy08's Avatar
Default Re: Questions on Sway bar's. (EBP-Si)
i have the suspension techniques swaybar/tie bar combo, 7/8" or 22.225 mm. although my car is an eg, i also have a rs*r ex-mag... i'm sure it'll be fine for you too.
Old Jun 5, 2005 | 05:30 AM
turboman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9800 &raquo;</TD></TR><TR><TD CLASS="quote">Well, my question is what sway bar willl beneifit me the most for like, backroad's and curvey roads.</TD></TR></TABLE>
still didn't say anything haha
everyone knows what I will say- no sway bars.
gofastgokart99
Suspension & Brakes
Jul 9, 2011 05:48 PM
. a d a m
Feb 10, 2007 07:50 PM
DreamCatcher
Suspension & Brakes
May 21, 2005 08:59 PM
