wiring my 90 dx hatch for a 91 b16a
im putting a b16a into my 90 dx hatch...and i hav all of the wrench turning done...but im not sure how to wire it...do i use the dx harness? if so how do i wire for injection, vtec, the knock sensor, second o2 sensor, and one of the distributor plugs doesnt match up to the b16a from the dx harness...need some help asap!!
Modified by antiricedout at 12:01 PM 3/7/2005
Modified by antiricedout at 2:02 PM 3/7/2005
This is MPFI info:
https://honda-tech.com/zerothread?id=881705
And this is info on B-series in a CRX (EF):
http://www.geocities.com/droppedcrxsi/
Also if you look in the Faq section of the CRX/EF Civic there are a lots of helpful information.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by antiricedout »</TD></TR><TR><TD CLASS="quote">im putting a b16a into my 90 dx hatch...and i hav all of the wrench turning done...but im not sure how to wire it...do i use the dx harness? if so how do i wire for injection, vtec, the knock sensor, second o2 sensor, and one of the distributor plugs doesnt match up to the b16a from the dx harness...need some help asap!!</TD></TR></TABLE>
Use the dx harness..
Convert it to mpfi and add the 4 wires for vtec..If you cant do it yourself then there are many places you can send your core and they'll build it for you..
