Obd0-Obd1 conversion -have cel for Map
Old Mar 6, 2005 | 06:59 PM
BoostBoi's Avatar
Default Obd0-Obd1 conversion -have cel for Map
After my conversion with Harness Adapter,P28 and Hondata install
I crank up the car and Idles great, After about 10 seconds if tripped the CEL for Map sensor, and the car wont rev past 2k. I replaced the Map sensor and checked
all connections. Still the same problem.
Please help A.S.A.P.
This is my daily driver, and I need it fixed by Tuesday.
Thanks, any info would be helpfull
Bryan
Old Mar 6, 2005 | 07:19 PM
Blown90hatcH's Avatar
Default Re: Obd0-Obd1 conversion -have cel for Map (BoostBoi)
What conversion harness do you have? OBD0 or OBD1 map sensor location?
Old Mar 6, 2005 | 07:31 PM
BoostBoi's Avatar
Default Re: Obd0-Obd1 conversion -have cel for Map (Blown90hatcH)
What?
I have the Non OBD to OBD1 conversion harness.
Map sensor is on the TB
Old Mar 6, 2005 | 07:44 PM
Who's conversion harness? Do you know how to read the pinouts so we can check the harness? Also, do you have the 3 bar checked in Hondata? Or the correct map sensor selected in Hondata for your application?
Old Mar 6, 2005 | 07:51 PM
BoostBoi's Avatar
Its a Hondata Harness , spent most of the day checking the pin-outs- They are correct, and the Hondata is set for the stock map sensor
Old Mar 6, 2005 | 07:56 PM
What color wires are on the Hondata harness? Do you have a vacuum leak?
Old Mar 6, 2005 | 08:05 PM
BoostBoi's Avatar
Colors ? most are just black-there all wrapped in Heat Shinked Nicely.
I dont have any vaccume leeaks,
I was running the AFC hack in OBD0 mode,no problems just running rich, then did the conversion today,
and WHALA- Map cell.
Old Mar 6, 2005 | 08:45 PM
BoostBoi's Avatar
Please help my car is my Daily, It must be running by tommorow night.
Old Mar 6, 2005 | 08:53 PM
So you confirmed the pinouts on the conversion harness are correct? Is the passage for the map sensor blocked?
Old Mar 6, 2005 | 09:10 PM
BoostBoi's Avatar
I just5 Checke d, No its clean.
GOD, this is PISSING ME OFF
Old Mar 7, 2005 | 07:45 AM
BoostBoi's Avatar
OK, I was miss informed the code is a 6 dor the Engine coolant temp, will that cause the same symptoms?
91redb20ef
Jun 27, 2019 09:14 AM
guessohw
Jul 11, 2012 01:39 PM
Meat_Wagon
Aug 10, 2008 06:59 PM
Meat_Wagon
Jul 21, 2008 11:53 AM
1.8T_EG
Feb 14, 2003 10:12 AM
